Please check out Leapfrog / Skip wiring vs plain Daisy-Chain wire
8400w Grid Tie System - Kit or piece it together?
http://solarprofessional.com/article...-wiring-methodComment
Doing that style usually means less length in the "home run" wires
give me the potential to add an SB3.0 down the road if I need more juice... and still be within the 10k and under regulations.Comment
You may be able to incorporate leapfrog wiring to shorten your home run to the inverter. Don't think this will work with landscape orientation. I don't recall your layout.
2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
OP....You are a true DIY'er.....Good luck but I don't think you will need it.Last edited by DanS26; 03-08-2018, 07:44 PM.Comment
Looks like I'll be over voltage in the cold months. The inverter I want to go with has the ability to run 3 strings... so I could just wire them up as 3 strings of 8 couldn't I?
Would make wire routing on the rack a bit more complicated, but would keep me within specs.
After toying with solardesigntool.com the SB7.0 seems to be a better fit when using 3 strings of 8 panels which would save me a bit of cost... and give me the potential to add an SB3.0 down the road if I need more juice... and still be within the 10k and under regulations.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
I'd have to go with something like a 2.8kw inverter which I'm not sure if anyone makes a grid-tie that small.
I'll do "skip" wiring more then likely.
As far as going with the SolarEdge, they look to make great stuff but it would put me over budget I think. I'll look into it a bit.Last edited by Mr4btTahoe; 03-09-2018, 10:20 AM.Comment
Well... looks like I've got somewhat of a plan in mind and the list about buttoned up. I'll turn this more into a project thread when I start ordering parts hopefully at the end of the month.
Dropping a couple trees this weekend to get the shade off the roof of the shop. Closing on our other house hopefully in the next week or 2 and then it is game on!
Thanks for the help guys. I'll post up with plenty of pictures as this progresses.Comment
Best of luck to you. looking forward to the photos.
Solaredge has a 6800 and a 3000 inverter in the hdwave series. You don't have to use the optimizers.Comment
OP is in US I believe. Which means that SolarEdge has HDWave models of 3kW, 3.8kW, 5kW, 6kW, 7.6kW and 10kW..... Not 6.8kW
It would be far smarter to install the SE10000H than two separate inverters
you DO need to install the optimizers with SolarEdge.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
IMHO two matched inverters are better than one large inverter. Why?........because you now can compare on an hourly, daily, monthly basis the production of each inverter against each other. You will know immediately if there is a problem in any panel or inverter by comparing outputs in real time.
This is true even if you have different orientations for each array and inverter since you will over time know and calculate the production differences between inverters.
This is not theory but real world experience talking.
plus you get more production from single inverter with multiple azimuths optimized then separate inverters as you can get to running voltage more easily on poor light conditions.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Yes but if you have an optimized system like SolarEdge you can compare ever pv module voltage, amps, production to others and to past results
Except there is inverter output reporting as well. Would be easy to tell from all the automated reports that the optimizers do not equate to inverter input or output.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
