  • unseengundam
    • Jul 2015
    • 13
    Need to clean MC4 connector? Spider webs, bugs, inside
    I have slowly working my ground mounted solar system and have an unsual problem. I my solar panels mounted, but the mc4 unconnected.
    I have found spiders and bugs love living inside the tiny mc4 connectors. Alot of connectors are now completely white innside with spider webs and other with dead bugs, etc.
    I tried to kill the pests and clear comb webs but its hard to clean up completely. I am worried a layer of cobwebs and bugs with cause electrical flow issues.
    Any suggestion on this issue? Should try soaking the connecotrs in water to clean them out?
    • 5213
    As I have advised before, MC4s should never be left exposed to the elements. They are not precious metal
    contacts, and a little corrosion ruins them. Panels should be kept shorted till hooked up.
    I suppose you could try some kind of contact cleaner, this before panels are connected together and put
    out significant voltage. I have had some so bad they couldn't be connected, those are finished. If they
    mate less than easily, I'd check them for heating up on maximum output. If they do, replace them (at
    night) before they get worse and generate smoke. Bruce Roe
      will a VCR head cleaning swab fit in there ?
      • gcherian
        • Mar 2017
        • 44
        Or a can of compressed air?
