  • lemonsocal
    • Jul 2016
    • 14
    Solaredge Consumption Meter and PVOutput Setup
    We just installed a consumption meter (WNC-3Y-208-MB) in my SolarEdge 7600 inverter.
    It is now appearing in the SolarEdge monitoring portal as it should--solar generation, self-consumption, and consumption are all reporting correctly.
    However, I cannot get the data (generation, consumption) to appear correctly in PVOutput.
    In the Automatic Uploads section with "SolarEdge" as the Primary Device, I've tried "Direction" in every setting (solar, consumption, net, both).
    Can anyone help with the PVOutput settings?
    Thanks.
  • lemonsocal
    • Jul 2016
    • 14
    I was able to figure out the PVOutput settings using a SolarEdge inverter with WattNode (WNC-3Y-208-MB) meter installed.
    In Automatic Uploads:
    Primary Device: SolarEdge; Direction: Solar; Poll Interval: 15 minutes; Energy: Enabled
    Secondary Device: SolarEdge; Direction: Consumption; Energy: Enabled
    --I read somewhere that consumption data is updated by SolarEdge only every 15 minutes, so you need to set Primary Device (Solar) Poll Interval to every 15 minutes so it matches up with consumption data.
    • JRqwertyui
      • Jan 2017
      • 49
      lemonsocal How does one enable the "Secondary Device" drop down, its grayed out for me...
      • gcherian
        • Mar 2017
        • 44
        That could be a bonus feature that will be enabled when you do a donation to support the site. I could be wrong - but I believe that is the reason.
        • macaddict
          • 132
          That's an awful large consumption in the middle of the night!!!!
          https://pvoutput.org/list.jsp?userid=59404
            • 15125
            Probably charging his EV.
              Might even be two EV's. Here is mine... midnight to 2 am is the Ioniq on the 240 V charger (7 kW), while 7 pm to 6:30 am is the Spark on a 120 V charger delivering 12 A (1.4 kW). The rest of my electricity consumption doesn't amount to much (~300-400 W).
              ~43 kWh consumed and ~39 kWh generated, but still banked $6.57 NEM credit with the peak / off-peak differential.
                • 15125
                Wow. Good thing you aren't off grid charging those EV's.
                • macaddict
                  • 132
                  Just wondering, how much does charging an EV add to your consumption? For example, on a normal day, with no AC, I use about 24kwh for a 24 hour period. If I were to get an EV, what should I expect by consumption to jump to?
                    It depends somewhat on the car, your driving habits, and the conditions, but something around 4 mi / kWh is decent. As of August, I had 31,682 mi on the Spark, with it reporting 147 mpge. Dividing by 33.7 gives 4.36 mi / kWh. That is 7283 kWh since the beginning of May 2015, 28 mo. About 260 kWh / mo to drive 1131 mi / mo. Actual wall plug consumption will be slightly higher, 10% according to some studies but it seems better than that when I've attempted to measure it myself.
