  • maximizese
    • Sep 2015
    • 59
    Stuck between two proposals
    I have two well reviewed (on solarreview.com, Yelp, Angie's List, Home Advisor), seemingly honest, and lower cost solar contractors and I'd like some input as to which system I should decide on:
    Contractor 1 option 1:
    4.76 kW DC
    17 Hanwha Q-Cells 280 Q.Plus
    1 SolarEdge SE5000A
    $15,000 or $3.15 per watt
    Contractor 1 option 2:
    4.64kW DC
    16 SolarWorld 290 Mono
    1 SolarEdge SE5000A
    $15,500 or $3.34 per watt
    Contractor 2:
    4.56kW DC
    16 SolarWorld 285
    16 Enphase M250
    $14,960 or $3.28 per watt
    Contractor 1 will add a 240V outlet for an EVSE in the garage (there's already a 240V for the dryer), and they will remove and reinstall the solar array when I have the house reconstructed (if they are still around in 5-10 years). I'm inclined to go with Contractor 1 option 1. Both contractors can start within 20 days and expect the install to take 2-3 days.
    • 14926
    Get your roof inspected and serviced. Fixing the roof under an array is a real PITA In terms of time/treasure. Give the roof under the array a good chance of lasting as long as the array probably will. Cheap insurance.You will not regret it.
    • cebury
      • 646
      Seems like you've done the basic evaluation between the two, and prices are within reasonanle range. You probably just need to go with your gut on 1st.
      • maximizese
        • Sep 2015
        • 59
        We had a roofer estimate the roof to last another 10-15 years; other solar contractors have given similar estimates. The removal and reinstallation will occur if/when we take the house down to the studs for an extensive remodel. The house is 60 years old and has been butchered by previous owners so starting over makes a lot of sense. We know the foundation is secured after having 32 push piers and 6 helical piers installed last year. Solar is on the menu for this year and going with Contractor 1 gives me a little flexibility in the future, again if the company is still around.
        • maximizese
          • Sep 2015
          • 59
          I guess you're right. Both contractors have very positive reviews and are so close in price. I guess what I was trolling for was whether or not someone would caution me away from Hanwha Q-Cells and the SolarEdge inverter. The 280watt series isn't the more efficient, but it seems like the most cost-effective at this time and I'm completely fine with that as I have plenty of roof space for potentially more panels.
          • cebury
            • 646
            You might try a new post titled with Hanwa vs Solarworld panels asking about company strength or opinions from the installers who lurk here. That'd attract a different crowd of responders than Help Quote 1 vs 2.
            The Solaredge pros and cons are listed here many times, but wish it were a sticky.
            If anything solaredge jhas strengthened as a company vs Enphase, it's competitor. But that doesn't prevent the newer to market competitors from taking criticsl market share over the coming years.
