Most Popular Topics
SolarEdge operational question
Except this is a two-quadrant optimizer; it can increase or decrease voltage and still be at MPP. So it needs a target.
If it's failsafe (and I expect it is) the inverter may drive the shutdown by NOT telling the optimizers anything for some time (10 seconds?) If the optimizers hear nothing for a while, they shut down. That way a loss of power, or disconnect, or fatal SW bug causes a shutdown automatically.Originally posted by butchdealalso it tells the optimizers very quickly the opposite, (rapid) shut down now
Although earlier Solaredge installations need a big relay to achieve 690.12 compliance, so maybe not.
Google "Solaredge rapid shutdown kit."
Edited to add - never mind, I'm wrong. The kit is just a new cable set with a new gadget on it. I assumed the switch had to be replaced as well so I assumed a relay, but it's just two cables in the inverter that need replacement.
The shutdown command could and clearly is lack of communication as you are disconnecting the optimizers form the inverter with the DC disconnect to engage it.
My point is that they are clearly getting some communication on a much faster bases from the inverter to operate.
The rapid shut down kit was just a wire with built in resistor. Not sure what you mean by a big relay.
The inverters all have it built in now.
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
The shutdown kit is 5 sets of wires good to converter 5 older inverters. One wire has a resistor.
It is and has been built in to all the inverters for some time now though.
http://www.solaredge.com/sites/defau...tion_guide.pdfLast edited by ButchDeal; 01-06-2017, 05:41 PM.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Yes I'm suggesting the target is to take enough energy from the panel (and deliver it to the inverter
string) to put the panel at MPP. For example if the optimizer output is 28V @ 8A (224W) but the MPP
would deliver 240W thru the optimizer, the optimizer will jack up its output to 30V @ 8A to get on MPP.
If the inverter sees the string voltage getting too high, it will pull say 8.2A and the optimizer above
will adjust to 29.3V out to get back on MPP. Bruce Roe
Yes, the inverter communicates with the optimizers, but not for the purpose of running the optimizer's control loops.Last edited by solarix; 01-06-2017, 07:42 PM.BSEE, R11, NABCEP, Chevy BoltEV, >3000kW installedComment
