Okay....another dumarse checking in.
I really wanted to avoid another "help me, I'm a solar moron post". However, I'm left with no choice at this time.
When I joined this forum yesterday I thought to myself...."okay, I'll gather the data I need,....spend some time doing the research and then post my somewhat educated questions.." Alright, that's not going to happen now...
First of all let me say that I'm VERY discouraged with the concept of harnessing free energy from the sun.....ha! I've quickly realized that the word free shouldnt ever be used in the same sentence as solar power. WOW, this stuff is expensive.......and kinda confusing to a solar newcomer.
Seems when you factor in cost vs savings the math doesnt compute.....at least no in my feeble mind.
My current hyposthesis is this: Solar is a super concept with great potential and is an ideal solution for certain applications. However, solar is not an efficient/effective way of saving money and getting off grid without sacrificing the efficiency of many of the household appliances and other modern luxuries. In other words, to use solar as a primary source of power we'd have to make concessions and significant lifestyle changes.......or at least change the expectations of the performance from our current appliances and whatnot.
If money were no object.....yada, yada, yada.....
but, it is.
Please feel free to correct me if any of the above is wrong.
Having said that......I'd still like to experiment with and use solar power. I'll give you two examples of what I'd like to do with solar power at this point.
1.) I have a radio shack that houses various communication equipment.....all 12v.......CB, Scanner, 2 meter transceiver, couple of output meters and a 400 watt amplifier. I'd like to add some back up lights inside too. Most of the time I spend less than an hour running the equipment......so, that means that I wouldn't spend more than an hour with the inside lights on too. The 400 watt transceiver amp is only for emergency use.
What would be sufficient to meet my needs as outlined above? I was thinking of a 100watt panel, a cheap charge controller and standard car battery......would that be work?
2.) The second need/expectation is for my house......if there were to be a power outage. I'd like to be able to power a light in each of the eight rooms, (maybe two or three in one room) and run a mid-size box freezer. Naturally the lights wouldnt be used during the day and at night they wouldnt be used all at one time.
Only one room would be wired with two or three lights.......maybe the living room.....this would be the gathering/meeting room. The rest of the rooms would only need one light that would provide sufficient lighting so to be able to navigate and perform normal tasks when that room is in use.
The freezer would be the only thing that would run constantly....if needed. I could probably run it during the day and turned off at night..?????
It'd be great if you guys could tell me if anything I've listed is possible......and if it is, tell me what components I'd need to achieve this.
Thanks!
but, it is.
Thanks!
