The sizes are a little different but mostly the STC difference. You would need more lg315 modules to get the same performance as the Panasonic 325 modules
Not sure if I should have tilt on panels heading 262 degrees or not.
@rsilvers
Beautiful home!
@Butchdeal
So you can generate a model like that just from a google earth photo and gps coords?! Awesome.Comment
Thank you.
In the end, I will probably do what ButchDeal came up with, except without the three East panels.Comment
We use google earth, LiDAR, street view when available, and homeowner photos some times.
We also have preliminary online estimates of costs and productions in many areas based on LiDAR all precalculated and instant online info.
We send proposals remote, customers sign, we send a local installer to review things, check measurements, and electrical issues.
An addendum is sent based on any changes, and there you go install starts.
Our entire national business model is based on this.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Very cool. I've been on the inside of it for so long that I haven't looked outward for what it has done insofar as what has (finally) come to market. I've been doing LiDAR design and development for the past 20 years or so with a few of the top companies in the field, deep in the trenches of refining what it takes to get to market what's affordable for given markets. My endevour has been mostly military stuff that is higher performance and yet to be available for commercial.
Thanks for sharing.Comment
Today is roof measurement day. They are coming over with a SunEye 210 to check shading on every roof facet.Comment
They are up-charging me 3 cents per watt more to go from LG315 to LG320.
One could argue that more dollars per watt is never worth it, but I am going to do it, since I want a larger system and am limited by roof space. Plus I will get more SREC2, and I will just feel better about having the latest.Comment
Due west (or east) panels are not that bad. Maybe a 10% loss from due south. Fixed PV panels produce most all of their power during a 6 hour window so 11am to 5pm is not much worse than 9am to 3pm. Use PVwatts to compare and you'll see. Tilting panels used to be more common back when they were four times as expensive. Now, put 'em flush so they will look good and can fit more in.
315w panels are 6.5ft long vs 5.5ft long for the more common, lower priced ~260w panels. The actual dimensions of your roof will dictate which size is a better fit. They are both the same watts per sq ft though.BSEE, R11, NABCEP, Chevy BoltEV, >3000kW installedComment
The LG 315 are 60 cell, about the same size as the conventional 250-280 W panels. The larger 315's described by Solarix are 72 cell like those made by Solarworld or Canadian Solar.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
I'd comment that the farther an installation is from the equator, the more beneficial higher tilt angles become and may be necessary if a system is expected to make cost effective production and/or reasonable winter production. Not everyone lives at 35 deg. or less latitude or has a high clearness index in the winter. Tilting panels is more work/expense, but may be necessary depending on application. Also, as you know, higher tilts have greater off south production penalties. New England is not the world's best solar climate. Flagstaff is pretty close to ideal.Tilting panels used to be more common back when they were four times as expensive. Now, put 'em flush so they will look good and can fit more in.
315w panels are 6.5ft long vs 5.5ft long for the more common, lower priced ~260w panels. The actual dimensions of your roof will dictate which size is a better fit. They are both the same watts per sq ft though.Comment
