Most Popular Topics
EMF radiation from inverter?
On another topic sort of, I posted in another thread, is a west external wall ok to mount an SE inverter? My neighbors house is about 20 feet east, it'll provide shading early morning.Comment
I'm familiar with those inertial reference units, earlier models used lasers fired in a prism to determine latitude by measuring the deflection caused by the amount of gravitational pull.I did a little over 20 years operating Inertial Navigation systems on subs. Extremely sensitive accelerometers monitor gravity vortexes with enough detail that we use them to navigate submarines. While remaining submerged for months at a time, we can circumnavigate the planet, while maintaining extremely precise navigation. While locked inside a steel pipe with a nuclear reactor, hundreds of nuclear warheads and lots of high power wiring. I have never heard of EMF causing interference to those accelerometers.Comment
Would not make any difference. Power Line Frequencies do not interfere with Radio or Sonar frequencies.
Now I know you are going to say Power Lines generate a lot of interference with radio frequencies which is true, but has nothing to do with EMF. That Interference is cause by the Isolators used to support the lines to towers and poles. When they crack or get contaminated the High Voltage arcs to the support structure which generates RF and Sonic emissions.
I have only witnessed one case where EMF caused interference with sensitive electronics. It was at a hospital in a Nurses station. Here old fashion CRT has distorted picture, or test lines. Hospital electricians tried everything they could think of and could not fix it. So they called me in to see what was going on. Took me 2 minutes to find the problem and fix it and collect a $1000 check.
Her desk was up against a wall, and the Monitor was up against the wall. I asked what was on the other side of the wall? Electrician answered: Electrical Room. Walked in and immediately seen a 3-pahse 480 volt 100 KVA Transformer against the wall. Guess what was on the other side of that wall? Yep her CRT. Moved it two feet and problem solved. The magnetic field was bending the electron flow in the CRT. Easiest $1000 I ever made. I knew what it was immediately, seen it before with a large magnet near a CRT. For whatever reason the hospital Electricians were not happy with me.
Morro of the story. Do not put a 2000 pound transformer in close proximity of anything that is sensitive to a magnetism. In this case within 3 feet. Only protection you need from a Small GTI inverter is a Tin Foil Hat or stay at least 6 inches away from it. Take your pick.
I can only think of one thing you would not want to put on or within a foot of a GTI. A Compass. If you are afraid of EMF, you need to get rid of everything you own with a Magnet. Start with your refrigerator or anything with a motor, phones, and speakers. If you do that, trust me, you need a Tin Foil Hat so everyone knows what you are and can stay away from you.Last edited by Sunking; 03-02-2016, 11:43 PM.MSEE, PEComment
All electronic equipment that could be used by consumers, including inverters are required by the FCC to be tested for compliance and labeled for electromagnetic interference. All home equipment is tested to FCC part 15 class B. FCC testing only tests above 450 kHz for conducted emissions (noise on the power lines) and above 30 MHz for radiated emissions (noise radiated into the air). The main concern of the FCC is interference to receivers. The inverters convert dc from the panels to 60 Hz by switching and filtering the output. Although the output is 60 Hz, there are a large range of harmonic frequencies that are generated by the switching and control circuitry. There are also low frequency magnetic fields generated. Although there are no health issues related to low frequency fields, operating electronics that is sensitive to low frequencies and receivers should not be placed next to the inverter.
I am new to this forum, but I am an Electromagnetic Compatibility Engineer (EMC).Bill - Phoenix, AZComment
Bill, good to have an EMI pro aboard. Could you give me an argument that will convince all the smart-meter fear mongers in my area that they don't need to worry about the EMI hazard of the new APS electronic AMI meters? (let alone the magnitudes higher inverter emissions) So far, I haven't found a way to break through their mindset and have lost more than a few solar jobs because the utility will not allow grid-tied systems without a meter upgrade. They don't take my word for it and I'm a former Avionics engineer with EMI testing experience, they don't listen to any industry experts because they are "obviously" biased and corrupt. The utility can't absolutely prove the meters are safe and the anti-meter people can't prove they are dangerous so we have a real controversy stirring in my community. I get the "Oh - I can feel the negative vibrations" all the time. We have a little emi meter that demonstrates how the emi from the stuff they fear is negligible compared to their cell-phone/laptop/LED lights/car etc etc but you can't argue with their feelings. The irrational mindset (as in the OP in this thread) makes me really wonder....
All the EMP/grid-down fears lately have been good for the off-grid side of our business though. Vanity/Jealousy/Lust/Greed/Fear - the foundation of sales and advertising...BSEE, R11, NABCEP, Chevy BoltEV, >3000kW installedComment
Usually, the people online complaining loudest about those EMI meters usually do so with a laptop across their legs while snuggled up in a warm, cozy electric blanket.
Dave W. Gilbert AZ
6.63kW grid-tie ownerComment
Unfortunately it comes down to a "trust" issue. A lot of people do not trust their POCO or any government official in general.Bill, good to have an EMI pro aboard. Could you give me an argument that will convince all the smart-meter fear mongers in my area that they don't need to worry about the EMI hazard of the new APS electronic AMI meters? (let alone the magnitudes higher inverter emissions) So far, I haven't found a way to break through their mindset and have lost more than a few solar jobs because the utility will not allow grid-tied systems without a meter upgrade. They don't take my word for it and I'm a former Avionics engineer with EMI testing experience, they don't listen to any industry experts because they are "obviously" biased and corrupt. The utility can't absolutely prove the meters are safe and the anti-meter people can't prove they are dangerous so we have a real controversy stirring in my community. I get the "Oh - I can feel the negative vibrations" all the time. We have a little emi meter that demonstrates how the emi from the stuff they fear is negligible compared to their cell-phone/laptop/LED lights/car etc etc but you can't argue with their feelings. The irrational mindset (as in the OP in this thread) makes me really wonder....
Most of those people are easily scared and can be convinced of something if it comes close to one of their fears. Sure some people are more "sensitive" to a lot of different things (sound, light, smell, etc) but just because they "feel" something does not mean it will hurt them or cause the illness that they are led to believe it will.
SunEagle's right: it's a matter of trust, just like many other science vs. activist disagreements (e.g. vaccines or climate change).
Many people find collections of heartfelt stories more convincing than actual expertise and scientific evidence.Comment
The APS electronic meters are no different that any other electronic equipment. They have to pass to FCC EMI requirements. I can think of no reason why one would be more concerned with those than any other piece of electronic equipment. There have been numerous studies relating to the effects of living close to high voltage transmission line. None of those studies have shown a correlation between living close to power lines and health issues. Of course all the studies recommend further studies.Bill - Phoenix, AZComment
Touche.
But to be clear. It isn't a trust issue. I am just not afraid of vaccines or climate change. And won't be bullied into making rash decisions on those topics.Comment
What is there to be afraid of from a health POV..
SMART METERS communicate via RF links. Many have a contract with the Local Cellular provider, meaning they have a small dedicated cell phone inside them. Others use the Paging Frequency bands once used by Radio Common Carries aka RCC which were put out of biz by cell phones. Others use their own licensed Radio Frequencies operating in the same 700, 800, 1900, and 2400 Mhz band Cellular, Biz, and government use. Lastly rural Coops may use what is know as Power Line Carries that have been in use since WWII.
Bottom line it is all low power RF and is no more of a threat than your cell phone. In fact with a cell phone stuck to your ear exposes your brain to 60 to 80 Db more power than your meter does. FWIW 60 to 80 Db is 1,000,000, to 100,000,000 times more power count the ZERO's. So if you are afraid of your electric meter, put on your TIN FOIL HAT when you talk on your cell phone. The electric meter is of no concern health wise. Your security and privacy is another issue, big brother is controlling and spying on you.
Lastly do not confuse EMF with RF. Two completely different things.
You might point out that cellphones emit the same sort of signals and are far closer to your head.
You might point out that if they were to wrap their bodies around the meter they might be exposed to as much as 100mW of non-ionizing (i.e. "safe") radiation - and by lying in the sun they are exposed to 50-100 watts of deadly cancer-causing ionizing radiation.
You might point out that they get exposed to far higher levels of ionizing radiation every time they fly.
Of course the utilities can prove (to any sane level of scientific validity) that the meters are safe. People don't care.The utility can't absolutely prove the meters are safe and the anti-meter people can't prove they are dangerous so we have a real controversy stirring in my community.
A few people do have some interesting sensitivities, but that has nothing to do with being harmful. A
program showed someone who could tell you when your phone was going to ring. "Answer your phone!"
that hasn't rung yet.
They didn't understand it, but credited it to future predicting. That wasn't it, but I know what it was. When
a land line phone is about to be rung, it is first disconnected from the 48VDC on hook battery. Within a
second it is connected to the ringing voltage generator. Some people can sense that change from 48VDC,
before the ring. Bruce RoeLast edited by bcroe; 03-03-2016, 08:01 PM.Comment
