HI, I am Chok here from malaysia. I have recently order some solarpanel range from 100wp to 10wp with 28cell which will produce 14Vmp. I would like to have some ideal either this panel can charge a solar gel battery with capacity 10ah to 100ah ?
The ideal is because of the weather in malaysia is always hot through out the year, so the battery doesn't required much voltage to charge during the cold weather. And also i am trying not to use MPPT charge controller as mosst of the MPPT charge controller starting doing the job when the voltage up about 15V, can someone correct me!
Thank you!
Thank you!
