In many cases, lithium ion (actually LiFePO4, which is similar) is _cheaper_ in the long run than lead acid, since they last far longer.
If you are having short term outages a battery system (with or without solar) can work well. For longer outages you are going to need a generator. And that's even if you add solar as well, because often grid outages correspond to storms which correspond to no sun.
Often well pumps are 240 volts. You will need either a transformer or a 240 volt inverter to support that load, and well pumps require notoriously high startup currents.
power goes out after big storms, particularly after ice storms. Because we're on a well no power = no water. The grid is aging and it's going to get more expensive as it's updated.
