i have a adaptor for car which i want to connect it to the solar battery. it has 3 adaptorss with usb output. Can i just cut the wire and connect it to the battery straight?
Most Popular Topics
connecting 12dc cigarette lighter socket to battery
Without knowing more about it, I'd say no. Got a photo or a sketch, or a link to where you bought it? we need to know more about what you plan on cutting into.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
This is the item http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
cut the end off which goes into the car adaptor. add 5amp fuse then connect it to the battery?Comment
Cigarette Lighter
Not sure about your USB but I have three cigarette lighters in a cupbconnected to my batteries charged by panels that I use a charging station and it works great! Check out the attached photo...[IMG]http://api.ning.com/files/qZzBys69B*F-ht-4lEEPQo1G-x8a3TSGpn0IMltKRaWAlbUFTRvUhKgNtk7MjC6nD1FtNxooqOv JMqkCl2Wv3aNxSSAnOLpE/charge.jpg[/IMG] or see it here ..http://mypoweronline.ning.com/profil...tion-wired-amp[url]http://www.livewindlangebaan.co.za/[/url]Comment
Yes you can,but what do you want to power with it? It has very limited uses of a max 3 watts output.MSEE, PEComment
Thanks i just wanted to know if it was possible without regulator. Don't wanna blow things up
. On the item description it says total output power 60watts I will be using it to charge AA/AAA batteries. USB charging and all. i will use in on the battery box that i made. Which i can carry it when the battery is charged when i go camping. And the charge regulator also stuck on the box. its like portable power with all functions.
Are those wires connected directly to the battery? don't you need something to regulate the power?Not sure about your USB but I have three cigarette lighters in a cupbconnected to my batteries charged by panels that I use a charging station and it works great! Check out the attached photo...[IMG]http://api.ning.com/files/qZzBys69B*F-ht-4lEEPQo1G-x8a3TSGpn0IMltKRaWAlbUFTRvUhKgNtk7MjC6nD1FtNxooqOv JMqkCl2Wv3aNxSSAnOLpE/charge.jpg[/IMG] or see it here ..http://mypoweronline.ning.com/profil...tion-wired-ampComment
regulator
There is a regulator for the solar panels on the charging end but yes they are connected directly to the battery, been running for over a year now no problem.[url]http://www.livewindlangebaan.co.za/[/url]Comment
there is a video of it here ...http://mypoweronline.ning.com/video/...gw-store-comes[url]http://www.livewindlangebaan.co.za/[/url]Comment
thank you very much. cleared my mind.Comment
in other words i can also connect it to the output of the regulator which the same as connecting it to battery?Comment
