I have designed and installed 3 arrays over the years plus did a major upgrade on one of the three. The things I can comment on are things about the installations
The biggest thing to keep in mind is that PV systems are generally permanent additions to a house. They all look pretty when new but every component needs to be something that will last 20 plus years at a minimum. The installers don't typically have the same time horizon that the property owner should have.
Plastic zip ties even if they are supposedly UV rated still have a finite life in the sun. Not generally an issue in the shade but I really need to switch to SS zip ties. I would not allow an installer to use plastic zip ties except possibly indoors.
Spend the money and run homerun wiring inside a metal conduit through the house. Conduit on the outside of the house looks like cr*p in the long run. If in doubt go with the next size conduit, the NEC fill tables are decidedly the minimum size conduit that wires can pass through but it will require lots of cable lube and pushing and pulling. The material cost to upsize is minimal.
Use stainless steel fasteners, no carbon or zinc or polymer coated . I use Neverseize on the threads. When I did a major upgrade of my pole mount, the stainless fasteners came right apart but all the zinc plated stuff came apart hard and on occasion I had to break them off. I buy boxes of stainless fasteners in bulk from a marine store and the cost is less per fastener than buying small quantities at hardware store. The quality is generally better.
All nuts should be nylock type self locking nuts, no lock washers. Lock washers are not much better than a regular washer in the long run and inevitably slow down assembly.
Even Gold Unistrut will start to rust eventually in outdoor conditions. Go with aluminum or stainless racking for the long run.
Spend the money on surge protectors and buy good ones. To date the Midnight Solar SPDs appear to be the best compromise between price and quality. Delta's may keep your house from burning down but don't seem to save equipment. (I got a surge from the power company and it cooked one of my inverters with a Delta on the AC side). I also believe in a dedicated surge suppressor at the panel prior to the wires heading into the house. Most microinverters advertise built in surge suppression but that only keeps the inverters from getting cooked, I believe in a dedicated suppressor to protect against a surge coming into the house from the panels. Installers tend to go cheap on surge protection and go with the minimum.
Solar isn't rocket science especially microinverter based systems. If you don't understand the basics or the contracts you are willing to sign ask more questions before you get to start a thread called "Solar Nightmare". Your learning should not come from the salesmen who are pushing you to sign.
