Lowest $/W for SunPower system
I've seen as low as $3.35 in the Phoenix area.Leave a comment:
[QUOTE=solar pete;162459]I have a quote for ~$3.85 / watt for SP including dual mppt SMA inverter at ~ 5 Kw system size. I came to this calculation by assuming the electrical panel upgrade I needed was worth $2500 and pulling it out of the quotes. Lower end LG panels (w/ ever popular SE optimizers and inverters) at about 60 cents less per watt. I'm leaning heavily towards the LG as I don't see a clear ROI on the SP.
This is from a recommended (by you folks) installer here in San Diego without haggling.[/QUOTE
Now I hope you are referring to the actual person who recommended said installer, as I am one of the folks here and let me assure you I or the forum do not recommend installers. I don't want to see people using this forum to make money through referral programs, I suspect that may already be happeningLeave a comment:
This is from a recommended (by you folks) installer here in San Diego without haggling.Leave a comment:
Since I can't reply to PM's yet, thanks for the PM mungosocal.Leave a comment:
Just got another quote in:
System 3:
8.84 Kw
Kyocera 260 panels
Enphase M215 micro-inverters
$ 3.88 w
Look like I'm still not getting close to your pricing mungosocalLeave a comment:
Thanks J.P.M and mungoSoCal that's very helpful.
mungosocal, would you mind PMing me the installer?
Cheers!Leave a comment:
Using SAM for an output estimate, LG 300's are est. to have an equal or slightly greater annual output per installed Watt than S.P. 327's using TMY3 Miramar data and my orientation.Leave a comment:
Howdy All,
I'm interested to know what the lowest $/W people have gotten in So Cal for a SunPower system? I'm in San Diego, and won't necessarily go with a Sun Power system, but I'm interested if people are seeing the high prices that I am:
System 1:
8.3Kw
$4.71/W
System 2:
6.87Kw
$$4.50/W
Cheers!
I've also seen a lot of ~~ $3.30 to $3.70/Watt systems equally fit for purpose, just not S.P., that have about the same annual kw/yr. per installed kW.Leave a comment:
Howdy All,
System 1:
8.3Kw
$4.71/W
System 2:
6.87Kw
$$4.50/W
Cheers!
