Most Popular Topics
Solar Edge Vs Enphase Power optimizers
I had looked at his system (on PVOutput) at the time the optimizer wasn't reporting, and have been following it since it is a bit of an outlier for production efficiency. In my opinion, the optimizer was properly producing power, even when it wasn't communicating. I suspect there are failure modes that would result in no power out, and there might even be modes that take down the string, but as far as I know, none of those have been reported here. There was another forum member recently with the same problem as makarowski, but I'll have to check my notes to see who it was.
As for the outlier in efficiency... it looks like better thermal performance to me, but I'm not sure. Some ideas:
1) The panels manufactured at the very top end of the + tolerance for power (someone's got to get the good tail of the distribution, right?).
2) The panels are installed high off the roof, so there is better air flow.
3) The location is near the coast, perhaps there is more wind, or more moisture in the air helping the heat transfer rate.
All of the zip code 9200X systems have generally been performing well, so it might be a combination of things that make his system stand out. Calibration is always on the short list too, but the calculated consumption data in PVOutput doesn't look skewed when the array is producing, which suggests that at least some of the outperformance is real.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
My system installed 3/2015
I have been lurking for a while, but decided to signup and make my first post about my system.
I had researched about 5 different installers/systems and decided to go with a SolarEdge SE5000, 20-250watt Qcell QPRo BFR-G3 250 panels with power optimizers.
My installer that I choose was great! VERY good contact, answered all my questions, did all the legwork.
I had to get my electrical service upgraded which included 2 new panels. I stuck by my guns and got 2 SquareD QO 250amp panels!!! Had to fight a little because they wanted to install Homeline, but I knew that QO was top of the line, and was familiar with them, and I got them.
I was on the fence with SolarEdge and Enphase, but when I found that panel level monitoring was going to go away, or cost, and my cousin had Enphase and has had problems with his install (of only 5 years), SolarEdge was my final choice, and I am glad I did.
Having the inverter on the roof in the HEAT, I knew this was a disaster waiting to happen. Being an electronics eng., I knew that heat is the number ONE enemy of electronics, and the inverter generates heat by itself.
I am a little disappointed that the most I have seen to date (excluding days with clouds) is only about 3.5Kw at high noon.
My layout is 11 pnls facing east, 4 facing south, 2 horiz (almost flat) at 7 deg., 3 facing west. Roof tilt is 27deg.
Also, my installer said that IF I wanted to get better monitoring rights on the web portal, I would have to become the installer and tell them when something failed.... so I plugged a USB cable into the inverter and am monitoring the inverter's data, can't log though....
I would like to know how to post a public link to my monitoring portal for all to watch, and signup to PVoutput.
Any ideas?
Thanks!Comment
I'd have to agree the old optimizer was generating power...I had looked at his system (on PVOutput) at the time the optimizer wasn't reporting, and have been following it since it is a bit of an outlier for production efficiency. In my opinion, the optimizer was properly producing power, even when it wasn't communicating. I suspect there are failure modes that would result in no power out, and there might even be modes that take down the string, but as far as I know, none of those have been reported here. There was another forum member recently with the same problem as makarowski, but I'll have to check my notes to see who it was.
As for the efficiency, its nice to end up on the high side... although not sure how real it is. I think you have something on point about being on the high part of the roof. I have two strings where the string on the lower roof with same orientation/elevation, (and gets wind protection from the next house) is not as efficient. no real shading on either strings... maybe I should have put more panels on my upper roof
PVOutput is using data based on SE monitoring data... I have tried to correlate with my SDGE bill... with some limited success
first month: SDGE measured a net of 32 kwh of usage, while the net from pvoutput was 109 (966 usage, 857 generation)
last month: sdge had a net of -194, while PVOutput had -203 (a bit closer, 1031 usage, 1234 generation)
I know a few people have been digging into the data to find where the errors are occurring... likely just the inaccuracy of SE data (rounded up and/or poor accuracy)... there are some wiered data points where my homes usage goes to 0 (which I know is not occurring)... "timestamps" of the data could also be a factor.
I'll eventually dig into it, but too much other stuff going on right now.
Cheers
BMakComment
Yes, it is timestamps and synchonization error, with a little bit of calibration error (maybe 1%) thrown in. Every time you get a "0" for consumption you will increase the error with respect to SDG&E.
To prove this, I wrote my own PVOutput uploader with a revenue grade data source so I have more control over synchronization. I also left a system on PVOutput that uses the SE data untouched. Yesterday was a decent example... You can see the good consumption data here, and the spikey consumption data here. My agreement to SDG&E for the first full month I ran the uploader was within 1 kWh.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
very nice...
I would think that since the SDGE meter data from Wattvision could be "read/timed" to coincide with the SE data, the timing portion could be solved without a revenue grade meter at PVOutput... then it would be just the accuracy of the SE data (1-5%)? not sure there is the control there down to the "second" on data polling..
looks like you are enjoying the same dark weather here in san diego ... solar generation went to about 0 at 3pm today...blah, its supposed to be summer!
Cheers
BMakComment
I would be happy to give you a 30 year warranty as an installer.
Costs me nothing. Incorporated so when solar falls off the cliff at the end of 2016 I will dissolve the corporation
Oh and that 20 year warranty just turned into a year and a half warranty.
I doubt your installer has even been around more than 6 years.NABCEP certified Technical Sales Professional
More likely an established installer will just be slow in 2017. I assume most have avoided adding much overhead. A lot of residential solar has been installed with only 1/3 of the customer's price being direct materials and labor. This business practice will not survive the end of the ITC, which is a good thing.
The end of wind was forecast in 2012. It looks like a 3GW Wyoming wind project will be built without ITC.Comment
I see you weren't around the last time the tax credits ended.NABCEP certified Technical Sales Professional
Good afternoon! Can anyone point me to where there is anything documented on panel level monitoring going away? This is the second reference to panel monitoring going away but when I contacted Enphase they didn't know what I was talking about? Or maybe they were just playing dumb? They even sent me the info on setting up an account etc.
Thanks!
Not sure what the real deal is?
Thanks!Comment
Panel level data is available, for a fee ($250, last I heard). The people saying it is going away are probably referring to the fact that it used to be offered for free, by default. Now, the installer pays for and enables it during activation, or if you self-install, you can take care of it yourself. If accurate monitoring is something you care about, in my opinion, the additional cost Enphase charges is worth the cost over the free monitoring from SolarEdge. However, for just basic status checks, either is fine.
More here:
I haven't installed one in years.
Your brothers would have been from the time when they still had it for everyone.
If you are the installer then you would get it. I believe they dumbed it down somewhat because of too many people callin in with issues that many times resolve themselves. ( communication between inverter envoy and Internet. )NABCEP certified Technical Sales Professional
Learn something new.Panel level data is available, for a fee ($250, last I heard). The people saying it is going away are probably referring to the fact that it used to be offered for free, by default. Now, the installer pays for and enables it during activation, or if you self-install, you can take care of it yourself. If accurate monitoring is something you care about, in my opinion, the additional cost Enphase charges is worth the cost over the free monitoring from SolarEdge. However, for just basic status checks, either is fine.
More here:
http://www2.enphase.com/enlighten-he...ghten-manager/NABCEP certified Technical Sales Professional
One more thing about monitoring... SolarEdge updated their API this month to allow up to 300 calls per day.
http://www.solaredge.com/files/pdfs/...toring_api.pdf
For those who want to do 5 min updates on PVOutput.org (288 calls / day), you can now.
They also added an API call to "Sensors", which supports adding a pyranometer, thermometer, or other devices to the inverter to make it a more fully featured data center.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Anybody? please?I have been lurking for a while, but decided to signup and make my first post about my system.
Any ideas?
Thanks!Comment
