There is better stuff out there for at least $0.50/Watt less. Why pay more?
5.1KW Costco Solar System.
I found a guy who is willing to install a system even if I don't buy it from him. He charges $1 per watt for the install. He also is going to send me quote but the said that for a 5kw system it will be around 20k... if I go with the Costco one and he install the system it will cost about 3k less than his own system.Comment
Can you tell me what system I could get for less? what part numbers? links? etc. Thanks
This one is same or better system than GrapeSolar from Costco for $1.73/watt (w/o shipping):
But you should consider the specifics of your installation, if you have shading issues then micro inverters or Solar Edge system may provide a better return long term after paying a bit more up front. Also don't forget the cost of city permits and roof mounts, wires, EMT, A/C disconnect box, and likely dozen other small things.Comment
