On SE web portal (see signature) the "Current Power" changes every few minutes or so. I'm not sure how it is calculated, but it's very erratic in partially cloudy days as the result of edge effects (light reflect and refract off cloud edges, and sometime focuses large amount of light onto a small area, like a magnifying glass) and cool temperature. So maybe for a few seconds or minutes it did reach 5.32KW, but definitely not over a long period of time.
Most Popular Topics
SolarEdge POWER Accuracy? 11,900 AC Watts from 12,000 DC array
I understand about the cloud affect. It is similar to reflected sun from snow onto a panel which can inflate the KW production numbers.On SE web portal (see signature) the "Current Power" changes every few minutes or so. I'm not sure how it is calculated, but it's very erratic in partially cloudy days as the result of edge effects (light reflect and refract off cloud edges, and sometime focuses large amount of light onto a small area, like a magnifying glass) and cool temperature. So maybe for a few seconds or minutes it did reach 5.32KW, but definitely not over a long period of time.
That is why there is research using concentrated or magnified solar pv panels so more photons can be captured to create a panel with a higher % yield.Comment
The last few days, the pyranometer next to my array has reported and recorded several periods from 1 min. up to 20 min. when the global horizontal irradiance reached over 1,100 W/m^2, with several of those 1 min. interval reading in succession over 1,200 W/m^2. The highest 1 min. irradiance was 1,267 W/m^2, 30 successive min. at 11:42 to 11:45 P.D.T., 05/18/2015. All high readings were only momentary and are due to reflections and forward scattering of sunlight by clouds. For the last 16 months, the highest clear sky P.O.A irradiance I've calc'd is about 1,030 W/m^2. There may be some ground reflected radiation component in there.Haha, you want to see something really funky? A few days ago I saw 5.32KW AC from my 4.8KW system.
[ATTACH]6748[/ATTACH]
I'm sure it's a combination of cloud edge effect + SE SW glitch. It's no way physically it can happen in any sustainable fashion. So I wouldn't pay too much attention to instantaneous measurements, especially in a partially cloudy day.Comment
Let us know if that irradiance stays high for an extended period of time. That might be an indication that the sun is somehow producing a lot more photons than normal. And you know what that means!!The last few days, the pyranometer next to my array has reported and recorded several periods from 1 min. up to 20 min. when the global horizontal irradiance reached over 1,100 W/m^2, with several of those 1 min. interval reading in succession over 1,200 W/m^2. The highest 1 min. irradiance was 1,267 W/m^2, 30 successive min. at 11:42 to 11:45 P.D.T., 05/18/2015. All high readings were only momentary and are due to reflections and forward scattering of sunlight by clouds. For the last 16 months, the highest clear sky P.O.A irradiance I've calc'd is about 1,030 W/m^2. There may be some ground reflected radiation component in there.
That's mostly because instantaneous solar radiation peaked at 1,100 to over 1,200 W/m^2 several times today. Nothing unusual for cloudy/pt. cloudy skies. Today's total around here is likely to be about 75% of a clear day's output for this time of year.Comment
Understood, posted to show that there can be even more surprising output numbers than in the OP. I think my inverter was clipping too, wondering how high the spikes would be with no clipping.Comment
