SolarEdge users: What's your inverter temp during high production?
Saw my inverter temps skyrocketing today and headed out to the store and picked up a $15 fan to see what effect it would have.
Right before setting it up, the inverter temp showed 163.1º and the outside temperature was right around 99.0º. Within a couple minutes the temp dropped by 7º and 30 minutes later, it dropped by almost 20º!
Obviously a temporary setup.
Originally posted by HX_GuySaw my inverter temps skyrocketing today and headed out to
Obviously a temporary setup.Comment
Seems to be working well...yesterday at 12:30pm the temp was 161 and today at 138. Hard to tell any difference producing wise as there been some clouds the last couple days.Comment
Checked the Kill-A-Watt and the fan used 0.25kWh in 7.5 hours of run time...which would equate to 0.33kWh for 10 hours (9am - 7pm)...if I ran it every day all year, that would be 120kWh for the year...and I probably won't even run it in the winter/spring (unless I see there is a benefit to it production wise, but probably won't be).Comment
I'm not home much during the day so just got around to checking my temp for you... 103.4deg on my SE3300 running 3.7kW array, putting our close to max power. Situated on the east side of house and its just before noon here so has been in sun all morning with current ambient temp about 85degF.BSEE, R11, NABCEP, Chevy BoltEV, >3000kW installedComment
1st Post!
HX_GUY I finally made it hereThis forum is nice, it seems a lot of solaredge owners here.
It was me who made the website with the typo's for the headerThe fans work great. My Inverter is inside my AZ hot garage, in a cabinet (that is open) the fan brought it down 15-20 degree's easily. Waiting to see what happens when its 118-120 out.
Always looking to improve my monitor!Comment
Se7600
Highest temps I've seen are 127-133 while showing 7700-7900 (w) output. Inverter is mounted in the garage and temp was probably in the 90's in the garage at the time.Comment
I was wondering (since I was curious as well) if the inverter temp could also be logged in pvoutput? I took a quick look and I didn't see a way to customize/extend the auto uploader for Solaredge ...
Any one else look into this?
BMakComment
Good question. Hope there's a way it can be done!Comment
