  • SanDiego_installer
    • Oct 2013
    • 46
    In Southern California you won't experience significant clipping, if any, on a 7.3 kW system using a 6 kW inverter. The power ratio is 122%. From experience, significant clipping occurs above 125%. And minor clipping in year 1 will disappear a few years down the road. Your contractor's cost difference on a SolarEdge 6kW inverter vs. a 7.6 kW is $478 + tax. Personally if a customer requests an inverter upgrade, after we have already agreed on the system size, scope of work and contract amount, I wouldn't mark up this minor change at all, and especially not by 35%. I guarantee you that at $3.30/Watt he's not making 35% on the overall contract, nor should he.
    Keep in mind the SolarEdge 7.6 kW inverter has two internal fans that will cycle on/off, whereas the 6 kW runs silent. If this will be mounted on a wall adjacent to a living space, not a garage, you will hear it.
    If you want the most reliable system, and have no shading, go with SMA. They have a 30 year track record. SolarEdge and Enphase have 7 & 8 year track records. By adding more components (optimizers or micro's) to the system, you will have failures during it's life. That's inevitable. If you have no shading, there is nothing to be gained from the additional cost and complexity.
      • 15038
      SunStalker:
      To your question(s) about more ways to save: Find/download this from the net: "Solar Power Your Home For Dummies". A bit dated but generally a good read. Conservation in chap. 2 & 3 may be useful to you.
      • SolarTuna958
        • Jul 2015
        What did you pick?
        Originally posted by SunStalker
        They upped the panels in the quote when I asked about the SolarEdge inverter. They originally did quotes with 20 and 27 panels. I think 27 may be a bit too many to fit on the roof anyways. Thanks for the info on the micro-inverters vs optimizers.
        Which system did you choose?
        I'm looking at a system similar to yours!
        SolarTuna958
        • SunStalker
          • Mar 2015
          • 10
          I ended up getting 26 Solarworld 285W Panels with Enphase 250 microinverters. I went with a different installer because I felt better about them and their long terms support of the system. I paid about the same per watt as I was quoted for the LGs. The installer did a great job and the install is very clean.
          The only thing I am unhappy with is that you can't monitor your usage vs production together. The Enphase monitoring is only for production. So I have to pull that up and then pull up SCE's site, which only shows net usage/production, and calculate the actual usage/production. My friends that have solar (Sunpower) can pull up a chart showing usage and production together.
            Additional equipment is required to monitor consumption. You can measure it yourself (using TED5000, EKM, Wattnode, or others), costing a few hundred $, or can read SCE's meter for yourself, using an Eagle from Rainforest Automation ($100). PVOutput can do the math for you to combine the Enphase readings with the Eagle readings to calculate actual consumption.
            • SunStalker
              • Mar 2015
              • 10
              My plan is to do the Eagle and pipe it to PVOutput. I was told SCE's up coming Green Button Connect might be able to dump the data to PVOutput. But I am losing home, it was supposed to be available in June, but it still says "Check back in June."
              Once I get both sets of data to PVOutput, is there a way on an iPhone to see both Production and Usage together. The App I use only seems to show them separately.
              • solardesire
                • Jul 2015
                • 11
                Hey SunStalker.
                We are in North Los Angeles county. We have several quotes, but none of them are close to what you got. Would you be able to PM me your contacts (since I amd a newbie amd can't PM anyone yet). Would love to get a great price like yours. Thanks
                Solardesire
                • SunStalker
                  • Mar 2015
                  • 10
                  Originally posted by solardesire
                  Hey SunStalker.
                  Solardesire
                  I will pm you shortly.
                  • outie
                    • Jul 2015
                    • 26
                    Hi SunStalker, could you PM me please too? The original and the installer you went with. Thanks!
