  • SunStalker
    • Mar 2015
    • 10
    LG 305s with SolarEdge Inverter - Los Angeles
    I'm almost ready to pull the trigger on a solar system for my home. For reference, here are the quotes I have gotten so far (No incentives included):
    Size/Panels/Inverter/Cost/$ per Watt
    6.1 20xLG 305 Enphase M250 $21,045 $3.45
    6.9 21xSunPower E20-327 SMA SB6000TL-US-22 $39,799 $5.80
    7.0 27xREC Solar REC260PE SolarEdge SE6000 $27,500 $3.92
    5.0 20xHyundai 250 SolarEdge $18,511 $3.70
    I am currently leaning toward the LG Panels, but I am not feeling comfortable with the micro-inverters. The company say they could to an SMA string inverter for $0.20 less per Watt. I would like to get the the LG Panels with a SolarEdge inverter with Power Optimizers. Every company except for the one using the micro-inverters said to stay away from them. I shouldn't have any shading issues on any of the panels.
    First how are the quotes looking? Second, is their an installer in the Los Angeles area (I'm in Northern Los Angeles in Santa Clarita) that will do the LG panels with the SolarEdge inverters? If so please PM me details.
    Thanks for the help.
    Without shade, it is hard to say that there will be very much difference between a string inverter, microinverters, or optimizers. There are a few mechanisms by which the panel level MPPT might outperform a single string inverter, but I have not seen any data that shows those marginal performance boosts are enough to justify the cost premium.
    Without shade, I've come to see choosing SolarEdge or Microinverters as more or less equivalent, and mostly in the realm of engineering curiosity more than actual performance. If you like to tinker and actually care about what each panel is doing, there are reasons why you might want SolarEdge and other reasons microinverters could be interesting; there is not a globally correct choice. Installers will talk bad about each other's products all day long, and I don't put much weight to those opinions.
    If you just want a lower bill electric each month and don't want to think about your system any more than that, without shade, a string inverter may be just as cost-effective as the alternatives, and probably more so. Careful review of systems on an aggregation site like PVOutput.org can support or refute this idea, but it will take some time and effort to compare the data carefully enough to be sure.
    • DanKegel
      • 2093
      $3.45 is a pretty good price.
      I agree, SolarEdge is worth considering.
      Is your house on http://solarmap.lacounty.gov ? (Maybe PM me your address?)
      Do you have any shading?
      Have you already reduced your energy consumption and/or gotten an energy audit?
      What are your goals?
      • SunStalker
        • Mar 2015
        • 10
        I do not have any shading assuming they can fit the panels on the two parts of the roof they say they can. If they have to use another part of the roof there would be some shading in the late afternoon from a tree and chimney.
        I just got an updated quote from the first installer for 24 LG-305s using a SolarEdge 6kW inverter with Power Optimizers. The price is $24,156 which comes out to about $3.30/W.
        So since they can do the SolarEdge inverter, I guess the million dollar question is the SolarEdge Inverter or the Enphase micro-inverters.
        Also is a 6kW Inverter large enough for a 7.3 kW system?
        I would like to also reduce my energy consumption, but I have not gone down that path yet. This size system would be covering 70-80% of my energy.
        • DanKegel
          • 2093
          Great. Are both sections south-facing, or is one section west-facing?
          They're pretty similar. Have you investigated reliability of each? With 24 units, that's plenty of chances for failure.
          The extra power would probably just be dumped. How much of the day do you expect to be generating more than 6KW?
          See also
          http://www.solaredge.com/files/pdfs/...zing_guide.pdf
          and
          http://enphase.com/eblog/2013/%E2%80...ldest-debates/
          I regret not doing that before installing my first solar system and an AC-powered hot tub Thinking about energy use in the whole house might have saved me some money.
          Do you at least have efficient light bulbs? (/me loves the Osram ones at Lowe's.)
          • SunStalker
            • Mar 2015
            • 10
            See also
            and
            All three sections of the roof that I am considering are south facing. I am leaning toward the string inverter because the lack of info I can find on the reliability of the micro inverters and like you I am concernded about having 24 of them on that hot roof.
            My house is 25 years old and does not hold heat (or coolness in the summer) well. I am considering having some newer windows put in. Are there people/companies that will evaluate the over all energy efficiency of your home and provide ways to improve it?
            I don't foresee doing anything that will increase our consumption. We already have an AC hot tub and ovens. If anything we may change or get rid of those. I do have mostly LED lights and dimmers about the house. I honestly can't see why we are using so much electricity. Last year was around 13,000kWh in a 2,800 sqft home.
              • 15052
              Suit yourself, but if you go down the use reduction path before you go down the solar path, your bill will go down more eectively and any resulting system will be smaller. Solar first and you'll reduce the incentive to reduce usage. Any resulting system will be larger ( more $$ upfront), and you'll have done the less economically effective stuff (solar) first.
              • thejq
                • 599
                Why did you change from 20 to 24 panels? Otherwise the 6K inverter would match very well. Your south facing roof is ideal for energy production, so the 7.3 KW system with 6KW inverter will clip quite often.
                I'm not too familiar with SMA's monitoring capability, but SolarEdge comes with life time per-panel monitoring for free. Enphase charges $250 I think. The latter two also allow you to integrate with pvoutput.org if you're into that.
                Besides shading, some panels can also be partially obstructed occasionally by bird droppings, leafs or dirt. The high temperature at where the micro-inverters operate can be a reliability and maintenance concern. The optimizer uses ceramic caps and is significantly simpler, hence in theory more reliable under high temperature.
                • DanKegel
                  • 2093
                  There are probably some more cost effective changes than new windows, but yeah, new windows can help.
                  There are most definitely companies that will do overall energy audits & offer improvements.
                  There are even subsidies for making those improvements. See http://www.energyupgradeca.org/
                  But don't pay too much for an audit... comparison shop first.
                  And you can do a lot yourself. For instance, you can get a kill-a-watt meter for about $30
                  that will tell you what any one plug is using. I found out my fridge was drawing way too much power that way.
                  So about 33 kwh/day on average? Yeah, you can probably do better.
                  No matter what your goal with going solar is, you can get partway there a lot cheaper by figuring out where your power is going, and fixing that first.
                  And then go solar for enough of the rest to get you well down into Tier 1.
                  • SunStalker
                    • Mar 2015
                    • 10
                    Thanks for the info. What are some of the more cost effective ways before looking into windows. My Spa is a hog when it comes to energy consumption. My house seems to use about .5kW without anything on (Air, Heat, Spa, Oven, etc). It never really goes below that. I have considered the Kiil-o-watt to see what is really using power. I will start that tomorrow.
                    I guess would like input on what you guys think would be good first steps to reduce power. I am only offsetting my electric usage by 70%-80% with the solar systems that can fit on my roof.
                    • SunStalker
                      • Mar 2015
                      • 10
                      They upped the panels in the quote when I asked about the SolarEdge inverter. They originally did quotes with 20 and 27 panels. I think 27 may be a bit too many to fit on the roof anyways. Thanks for the info on the micro-inverters vs optimizers.
                      • gvl
                        • Mar 2015
                        • 293
                        Is there a filter that you run for you spa every day? For pools a variable speed pump is said to be much more economical than a fixed-speed one. Energy efficient lights in high usage areas. Better attic insulation.
                        • DanKegel
                          • 2093
                          Might be good to start by doing daily meter readings and tracking them in a spreadsheet.
                          (If you have an old fashioned dial meter, don't worry, it's easy after you get used to it.)
                          After a little while, you'll start to notice patterns (like "running the dryer uses 2kwh"
                          or "that weekend we left the computers on used an extra 3 kwh").
                          Have you set your computers to sleep on idle?
                          has a checklist for your hot tub that might be useful.
                          The hot tub probably uses 10kwh/day, and I have trouble getting
                          my house below 15 kwh/day, so you might only have an extra 5kw/day
                          to find and remedy.
                          • timmybgood07
                            • Mar 2015
                            • 6
                            Hey SunStalker. Would you be able to PM me your contact. Would love to get a great price like yours. Thanks
                            • Carl_NH
                              • 131
                              No, you should get the SE7.6 KW inverter be clipping for 4-5 hours of the day, and if you have no shading issues, go with a straight string inverter like SMA and keep it simple.
                              I put in 24 LG300 with SE6KW inverter, and optimizers as I have shading, and we are clipping for 3 hours a day, and had I known the 6KW inverter only outputs a max of 6000W AC I would have upgraded to the 7.6KW inverter ($700 more).
                              One other member calculated we will loose less than 200KW a year from clipping so the ROI for $700 isn't great.
