LG vs Sun Power
If you are uncomfortable with the LG Ace micros, you should be able to get a proposal for standard DC LG300 panels (or something else) and match them with the inverter of your choice. The cost difference for the Sunpowers you've been quoted is significant, and is unlikely to be made up even if the Sunpowers perform as advertised. One way to put the comparison in perspective is to consider what it would cost to install enough "standard" panels for you to match Sunpower's output some years from now. One example of that is here. -
Hello
We are considering solar panels for our home.
The cost structure is different between the two - SunPower E20/327 ($4.30/DC watt) vs LG Mono X Neon with Mono X ACE micro inverter ($3.80/DC watt). LG has 300 W peak power output/panel.
has anyone used LG Mono X Neon with Mono X ACE micro inverter ? any experiences ?
Sun Power panels with Sunny boy inverters seem to have more history to back up the efficiency and numbers promised on their brochures. any thoughts ?Leave a comment:
LG vs Sun Power
Hello
