Wow, $400 for the combiner box? I don't claim to know the pricing, but at a quick glance it's just a simple metal box with connection hardwares on the inside. I may be wrong but I don't think there's fancy electronics involved inside. Seems like it should be around $40 instead of $400. Maybe someone more knowledgeable on the pricing can chime in here.
Most Popular Topics
Mounting inverter in Phoenix: Garage or Outside?
You can pay $400 for a breaker box and four breakers if you choose an expensive brand and buy individual parts. But even if you go for a package deal, getting all the way down to $40 will be difficult if not impossible.
Unless the manufacturer is a UL approved panel shop, you will be paying for a standard assembly which is UL listed for use as a sub panel as well as for use as an AC combiner.
Even if the individual inverters contain output breakers, the NEC requires you to put a branch circuit breaker for each one at the combiner.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Looking on Google, I'm seeing prices of $85 - $600+ for "Solar AC Combiner Box" so I guess it's possible, I have no idea which one he was specing out.
I did email them last night with links to the inverters, showing a difference of about $1200 between two smaller PowerOne inverters and one big Fronius inverter and asked if they could do it for $2000 installed. I'll see what they say today.Comment
My installer offered me 1 inverter or 2 it was up to my choice, after doing some research I opted for 2 and it was no extra cost. the same price either way. It was a little bit more work installing, had to hang 2 inverters extra materials and installation of the secure power supply and combiner box.
It shows that the "Full Power MPPT Voltage Range" is 200-530 but then says "Operating MPPT Voltage Range" is 0.7xVstart - 580.
What's the difference between Full Power MPPT Voltage Range and Operating MPPT Voltage Range?
And it says the Vstart is 200 but adjustable between 120-350...so why wouldn't you set that as low as possible (120) so that the system would start up faster as it reaches that voltage? And if you set it to 120V Vstart, then the MPPT operating range would be 84V? Seems the lower the voltage the better it would be if there are shade issues, no?
Bah! Heard back from the installer and they're saying +$3800 for the 2 inverter setup with the inverter price being +$1000 per inverter ($3500 for (1) Fronius and $2500 each for the PowerOne. Then the UL combiner box at $350 and the rest for conduit, wiring and 6 hours of additional labor. He is saying that it's basically like installing two systems because per code, he can't run all the wires in one conduit, he will have to run two sets of conduit, one for each inverter...is that correct?
I'm trying to see if they will come down on the price some more, if I can get it to $3000 I think I would do it. Just seems like a much better way to go between the better inverter (operating temp of 160º, derate after 122º vs operating of 122º, derate after 104º of the Fronius) plus having each string on it's own MPPT and not losing the south roof strings for basically 4-5 months out of the year.Comment
Hmm, that could be an option. Would the rest of the install, aside from plugging in the optimizers, be the same as doing a regular 1 inverter install?
Looks like to get the most out of the system, you need to use a SolarEdge inverter as well, but the price seems good at around $2500.Comment
Great...more things to research!
Seems orientation and string length does not matter between strings so I could have 14 east and 8 south and 12 west if I wanted. Minimum of 8 panels per string and maximum of 25.
http://www.solaredge.com/files/pdfs/products/power-optimizers/se-power-optimizer-ao-datasheet-na.pdfThis page is not found but don't worry, the sun is still shining! We are here to helpComment
http://www.solaredge.com/files/pdfs/...tasheet-na.pdf
Enphase is good choice, but not a good choice for your area since you have extreme high temp summer. Try solaredge, I think it might be a better option for you since your shading is not just "a little". I am not a solar expert, but if this is my solar project, I'll choose solaredge.
Good luck.Comment
I talked to my installer and they have no experience with SolarEdge, never used or installed it. They have done micro-inverters and he said it's probably similar on the panel install side. He did say micro-inverters need some sort of extra ground that's not needed when doing a string inverter? Is the same true for SolarEdge?
Price wise, the SolarEdge inverter and 48 optimizers would be about $5,400 going by online prices. He said the Fronius inverter is $3,500, so looking at +$1,900 minimum. I'm sure they would upcharge it a bit but shouldn't be more than +$2,500 I wouldn't think vs the old Fronius install. But, the SolarEdge has built in wi-fi monitoring *I think* where as with the Fronius it's an additional $800 and it's a must for me, so really the net additional would be +$1,100.Comment
6 additional hours of labor to put in an additional inverter! I think it only took my guy eight hours to install everything 2 inverters, 2 DC disconnect, 2 secure power supplies, trough, combiner box, meter, disconnect and mount the sheet of plywood to the wall.Comment
You should see how my installer charge me 6 hours X 2 labor = 12 hours to do a 2 panels addition. lolComment
