Dear Sun Eagle, Thanks for your comment. I have already stated my opinion why the NEC and Underwriters has not approved these devices yet. I hope that when they convene again, they will address this issue. I do recommend, however, that they be installed on a dedicated circuit .
Plug-in Grid tie inverter
In researching grid tie inverters, I've run across models that plug directly into 120v AC wall outlets. This begs the question: for a grid tie solar system for the purpose of powering a home and selling power back to the grid, can you have a setup as simple as: Solar Array > DC Disconnect > Grid Tie Inverter > Wall Outlet ? (Granted, it would need to be low-wattage since it would be going through the normal wiring and not heavy-duty hard-wired to the main power box)
[ATTACH=CONFIG]3803[/ATTACH]Comment
mike, if you would like to talk about these devices intelligently, please let me know. as far as safety, back-feeding or overloading any circuits, if you plug them into a dedicated circuit, any potential problems are eliminated. like i told you, i am a master electrician in MD and am fully qualified to comment on these devices.- Is illegal
- does not meet UL or NEC
- can get the homeowner fined
- Can get the service turned off
- can easily be plugged into a different circuit endangering the occupants
I also find it strange that supposed "master electrician" would resurrect a 3 year old thread to state how much he likes the illegal item
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
I don't really understand the point of having a plug in device but requiring a qualified electrician to come plug it in. Also the dedicated circuit sure, sounds good till someone plugs it into another circuit.
So if there is a qualified electrician installing it WHY not just install a certified, UL listed, NEC approved wired in inverter?
Also many interconnect agreements don't like unbalanced 120V inverters on only half of the single phase.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Now if that inverter was 'hard wired" to a dedicated circuit breaker or if a special receptacle or "connection point" was the only wiring device connected to the circuit breaker and it met the required UL listing I would say it could be done. Doing anything else opens you to losing any insurance claims if that system fails and causes damage.Last edited by SunEagle; 08-28-2017, 01:05 PM.Comment
For example, let's say a homeowner has an air conditioner and a hairdryer that are both plugged into the same powerstrip in their bedroom. Works OK for a while. But then it gets hot out and the A/C is running full blast - and the breaker trips when they use both. This annoys them. But then they think - hey! I have that solar power thing that gives me power. I'll move it over here and plug it into the power strip, and it will help out the A/C when it needs a little extra power.
So they do, and it works well. They pat themselves on the back for their ingenuity. And now they have a15A rated circuit carrying 25 amps.
How do you avoid that? Hardwire the inverter.Comment
mike, if you would like to talk about these devices intelligently, please let me know. as far as safety, back-feeding or overloading any circuits, if you plug them into a dedicated circuit, any potential problems are eliminated. like i told you, i am a master electrician in MD and am fully qualified to comment on these devices.Comment
there's fundamental safety flaw in these devices- a plug is made a power source contrary to widespread belief it belongs to a power consuming device. I was badly shocked once (220V AC) from such plug when someone came up with bright idea to make it source being simply out of necessary connectors: the plug was on a desk among others, I took it in my hand and was immediately shocked. Luckily I was able to let plug go as there was nobody around at the time to turn off the power. I wish all these 'inventors' get into their own traps once in a while.
I understand these devices might turn off output immediately after they get unplugged but still making power source ending with a plug is a terrible idea.
If it can be unplugged it will be, and will be used on other circuits. (Which is why you put plugs on devices.) In fact, homeowners have demonstrated a perverse sort of ingenuity that they employ to get around problems; any electrician will have half a dozen stories of the horrors they have seen when debugging homeowner electrical problems.
Thank You for you well thought out Example. I am aware this type of stupid installation could happen. I guess the answer, to help them get UL listed, is to make them hardwired. That should help. Still, when your dealing with solar panels, usually the person knows what they are doing. By comparison, the example you provided, this kind of abuse could be done with a simple Space Heater. Why is this Clean Energy Device treated so differently ?
When it comes to electricity someone getting hurt or worse is usually the end product of being complacent. At least that is based on my 40 + years of experience in the electrical power industry.Comment
Supposedly, the idea of the plug is to make it easy to install. By the time you run a dedicated circuit for a receptacle, why continue to try to use the plug?Comment
Dave W. Gilbert AZ
6.63kW grid-tie ownerComment
