Hi all, I am trying to figure how many KWH's my Battery bank needs to be to run my home at current usage. Last year I used 7382 KWH at home. If my math is correct that is about 20.50 KWH per day using a 30 day month. Now if I wanted to store enough power for 2 days and not taking the Battery Bank any lower then say 60% how many KWH's do I need. I also need to figure out how long it will take to charge the system using 720 watts of panels at 12 volts. I am still unsure if it would be better to use a 12 volt system or switch to 24 volts.
Thanks for the help
Jack
Thanks for the help
Jack
