I agree Russ, but if I didn't mention it, someone would bring it up that I didn't give all the information, so in the interest of full disclosure. The difference between my west and south facing panels for the past 30 days is less than 1 watt hour so as you pointed out, no real difference. The real factor was the wattage difference between the Power-One inverter (250w rated) and the Enphase inverter (215w rated) along with the panel wattage matching.
Advice on proposed equipment
I prefer the
I prefer the Power One Micros over the Enphase. One thing Enphase has done consistantly since day one is run in the red. Power One has actually turned a profit and they are sized more correctly for the 285w panels. Enphase typically will clip around 225w. Is a string inverter an option?Comment
They do have string inverters available from 2kw to 6kw. Power-One is being acquired by ABB so they will even have more resources.I prefer the Power One Micros over the Enphase. One thing Enphase has done consistantly since day one is run in the red. Power One has actually turned a profit and they are sized more correctly for the 285w panels. Enphase typically will clip around 225w. Is a string inverter an option?Comment
