I have received a bid that I believe that I am ready to accept and would like everyones opinion on it: Location is North Las Vegas, Nevada. No Blockage. String Inverters have been looked at and the ones quoted to me were either undersized or oversized except for the sunpower system which I couldn't afford.
19 Mage Solar USA Powertec Plus 250/6 ML
19 Power-One Aurora Micro-0.25-I Micro-Inverters
Power-One CDD Monitoring System
Roof Mounting
All Interconnections and wiring
All Permits, paperwork (HOA, PUC, Utility)
4.75KW
8433 Kwh
$17,580
$3.70 per watt
Gives me 91% of last years usage but that was before I upgraded the attic to R-50 and radiant barrier. May already showed a drop in usage. Nevada is a Net Metering State so I don't want to go too much over my usage. Estimated break-even is 5 years.
My thought process - I am aware that the Power-One micro-inverters only have a 10 year warranty and accept that. I have a hard time believing that anyone is going to be able to support a 25 year warranty anyway. I rather believe in a bigger company like Power-One now that they are being bought out by ABB will be around in five or ten years. I was also offered the Enphase micro-inverters at the same cost with nearly the same performance. Believe it or not, I liked the monitoring system with the Power-One better than the Enphase Envoy.
So let me know what you think. Give me the bad, the good, the "are you crazy!".
Roof Mounting
4.75KW
8433 Kwh
$17,580
$3.70 per watt
