Outback Radian questions and suggestions for new grid tie hybrid system.
    • 3650
    Originally posted by df0rster
    That makes sense. I am not yet too familiar with all the features of the hybrid inverters. I just wanted it for its battery backup capability and zero export and other features and options, and the salesman recommended it to me. I thought he also told me that it didn't have an automatic transfer capability for backup, but maybe I misunderstood..
    A subpanel won't be a big deal for me. I could probably move everything except my water heater and AC unit to the subpanel for backup.
    Does the skybox provide all of its 5000w in backup mode also?
    The skybox seems very reasonable for all it does..
    The Radian actually had two backup modes, one that took a second to cutover to backup mode and another that was instantaneous but took more overhead because like a UPS it was constantly syncing with the grid. The Radian would require a separate charge controller if you wanted solar. The Radian has a transformer so it can handle larger surges like well pumps or Air Conditioners. I do not remember much about its grid zero mode.
    Yes, the Skybox inverter can handle 5000 Watts but I don't think it could power your electric instantaneous water heater.
    Propane would be a much more efficient source of instantaneous hot water. I actually use a Rheem heat pump water heater and while it takes a 30 Amp breaker, I only run it in heat pump mode and it draws about 15 Amps.
    • df0rster
      • Jun 2018
      • 127
      Yeah I won’t use the ac or water heater during outages. I don’t plan to have many batteries. Just enough for a couple hours of essentials (coffee and tv!!). And fridge or course.
      I could easily reroute my propane tankless for showers if needed. It only draws a few watts to run the exhaust fan.
      my next problem will be a good way to get my pv wires into my mechanical room where I want the inverter. I’m thinking of running them up the side of house behind the gutter and over the roof into the ridge vent space. That way I don’t have to cut any new holes.
      can I put my fla batteries in the mechanical room? It’s not ventilated so that may be an issue.
      thanks for all the help!
        FLA batteries need venting, they can create stinky fumes in the later stages of charging, and acid mist can sometimes escape the vent caps and corrode metals and electronics.
        AGM batteries are much the same. When new, and charged properly, no problems, but in age, as they fail, they can vent flammable fumes just like their FLA cousins.
        And no sources of ignition (brushed motors, relays, alternators, pilot lights.....) should be in the room
