I have a 4.88kw system with Schneider elecronics. I want to see the production of the system away from home. The Conext Combox is connected to my wifi as well as my cellphone, but I can only access it at home. What am I doing wrong?
Connectivity?
to view it outside your homes local network, you need to create a PORT through your Router. Best left to a computer guru, if you do it wrong, you expose your home network to the global internet of hackersPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
As @Mike90250 said, you can modify your router's configuration to do port redirection of your public IP to your Combox's IP. You can combine that with a Dynamic DNS service.
Alternatively, you could let a computer running at your home (which has access to your Combox) with TeamViewer or something else and access it remotely. If you know networking very well, you could also combine a VPN + reverse tunnel (that's what I do) to access it from anywhere.
Finally, if all the above options aren't good, you could scrap the Combox and get a Conext Gateway.Comment
