So I installed a grid-tied solar system with battery bank two years ago and it has been working perfectly. Now I'm having an issue. The AC output has zero interruptions during the night when it's working just on batteries, but during the day there's occasionally a 1-2 second loss of AC output (lights flash, appliances flicker or shut down) when a load is turned on ( or the fridge cycles on). This problem does not occur at all once the sun is down. I've never posted before, but have read a lot of useful post and info on this site, so thank you.
Help Troubleshooting Hybrid System
If your system is a typical hybrid set up, you are not running just off batteries after dark, you still use the grid unless the grid goes down. I have a hybrid system (actually dual, one part is just grid tied, a second part is battery back up and grid tied. I get no loss of AC at any time.
However I have no idea what is malfunctioning.6,32 KW solar, net metered, maple syrup producer. -
I am not sure exactly why you are experiencing those flickers but there could be a problem with your inverter software and the specific properties of the grid. Sometimes a slight voltage dip or frequency change can cause a grid tie inverter to balk and fail to work momentarily but I am just guessing without more data.So I installed a grid-tied solar system with battery bank two years ago and it has been working perfectly. Now I'm having an issue. The AC output has zero interruptions during the night when it's working just on batteries, but during the day there's occasionally a 1-2 second loss of AC output (lights flash, appliances flicker or shut down) when a load is turned on ( or the fridge cycles on). This problem does not occur at all once the sun is down. I've never posted before, but have read a lot of useful post and info on this site, so thank you.Comment
What brand and model of inverter are you using?9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
