I'm fairly new at this and I need help coming up with a design for my system. I think I have the solar panel positions figured out with 3 orientations, ranging from 6-10 panels each. I want to go with a solaredge system because of some shading issues. What I need help with the most now is the wiring becasue I don't know much about it.
This is what I want to do: I want to have the inverter installed in a way that I can add a generator to the system down the line so that I can have some power during our yearly outages. The generator is going to come a little later after I pass the inspection, but I want to have everything ready for when I get one so that I just have to plug it in when needed. I would also like to add a couple of panels in the backyard mounted on the ground maybe in a year or two for some anticipated increase in electricity need, but this is just secondary.
How do I need the inverter wired, in general terms? Do I need a switch between the inverter and the electric panel? It makes more sense to have a switch between the inlet from the power company and the electric panel, but I'm not sure if this is even possible. I know I need something to avoid backfeed onto the power lines, but I'm not sure how this is generally done in order to also provide power from the solar system to the electric panel. If possible, I want to avoid having a critical load subpanel to keep it simple and keep cost down. My electric panel is a little unorganized and it would take some work figuring out which wiring goes into which breaker. If power goes out, I would only be using the critical stuff anyway and all I need is to run are the lights, refrigerator and the central AC (and ideally even the internet and security cameras) and having to rewire everything to accommodate a subpanel may be cost prohibitive, but I'm not sure what the costs involved are even going to be so I would appreciate any suggestions.
