I recall (but cannot locate again) a review stating the the newer Grape panels are now negative ground instead of positive ground. That may be true, which would still be unfortunate, or it may simple be a misinterpretation of the fact that neither side of the panel is grounded.
If either side of the panel output is grounded (actually connected to the frame), you can kiss the idea of putting them in series goodbye.
Unless, of course, you connect a negative ground panel in series with a positive ground panel to produce a center grounded system.
lol I thought negative ground was the way to go for simplicity of other components.
about the #GS-S-100-Fab36(the not positive grounded one) being a frame bonded ground.
