Hi there, I was just wondering if anyone has used these and weather or not hey worked well for you. It would be to make AC for a wood shop. Thanks!
PowerJack grid tied inverters, worth a damn?
Are you mentioning the wood shop because it has its own metered electrical service and you do not want to spend money which you could not recoup because net metering in your area will not allow you 12-month bill to go negative?SunnyBoy 3000 US, 18 BP Solar 175B panels. -
[SIGPIC][/SIGPIC]Comment
Thanks for your replies! Right now there is no power in there yet but will have a small service soon to run the shop stuff. For the AC (Air Conditioning) I was gone go with my DIY panels with 72 3x6 cells in each going to a PowerJack (maybe not if they suck) going in to the plug in the wall of my shop. The MAIN thing that concerns me about the whole thing is the posability of injury to a lineman during an outage. The PowerJack inverter is rated to take in 14-36 volts DC and output 120v 60Hz Pure Sine wave, it also will not work if it does not sense AC (Alternating current) from the outlet that it is plugged in to.Yes, no, FUBARed? How would be the best rout but still be worth it, and be safe for linemen.Comment
Would it be possible to run a 120v leg thru a blocking diode and then to the wall plug that the PowerJack (or some other inverter) and air conditioner are plugged in to? Then I would have current for the inverter to sense and thefor function, but in the event of an outage it would be a second line of defense against back-feeding the lines?Comment
Screw the lineman safety, you are a biz man and number one priority is will it make you money. Answer is NO it will not. Between your home made panel, no credits, and poor efficiency it will never pay for itself. All it can do is cost you a lot of money in liability if you are caught with it or hurt someone.MSEE, PEComment
Not really. Th eonly possible scenario is to purchase a fully legal and compliant system installed by the pros in a Grid Tied System. If conditions are right in 8 to 10 years it might pay for itself by letting your neighbors pay for most of it. At the end of that time when you break even you net 0% ROI.MSEE, PEComment
Would it be possible to run a 120v leg thru a blocking diode and then to the wall plug that the PowerJack (or some other inverter) and air conditioner are plugged in to? Then I would have current for the inverter to sense and thefor function, but in the event of an outage it would be a second line of defense against back-feeding the lines?SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Screw the lineman safety, you are a biz man and number one priority is will it make you money. Answer is NO it will not. Between your home made panel, no credits, and poor efficiency it will never pay for itself. All it can do is cost you a lot of money in liability if you are caught with it or hurt someone.Comment
Not really. Th eonly possible scenario is to purchase a fully legal and compliant system installed by the pros in a Grid Tied System. If conditions are right in 8 to 10 years it might pay for itself by letting your neighbors pay for most of it. At the end of that time when you break even you net 0% ROI.Comment
ohhhh yeah... well it shuts down if it doesn't sense AC. So instead of the plug and play rout would I do better with batteries? Now THAT sounds like an expensive pain in the dangerous ass to me.Comment
Maybe, maybe not. If you spend $1000 on the materials and spend 200 hours building it and it only generates $100 worth of power before it fails.... Well all I can say is you really stuck it to the Man at the Power Company. That man is you with a $900 loss and a lot of time wasted learning the hard way. If your time is worth $10/hours then what?MSEE, PEComment
Maybe, maybe not. If you spend $1000 on the materials and spend 200 hours building it and it only generates $100 worth of power before it fails.... Well all I can say is you really stuck it to the Man at the Power Company. That man is you with a $900 loss and a lot of time wasted learning the hard way. If your time is worth $10/hours then what?Comment
You could either cut your losses by not investing time into construction of panels or else use them to directly power something with DC just when the sun is shining.
Or you could repackage them one or two cells each as starter solar experimentation kits and sell them.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
