I can pull permits for DIY install of approved UL equipment (have talked with a few others in my area that have done so). As for DIY panels the cost is now much higher than factory built. I did play with a kit a while back just t learn but it wasn't a full fledged panel just a few cells together. An educational moment. My point in posting the video was just that there apparently was a DIY panel setup that received approval (based on the video - again would need to see the permits for 100% confirmation) for grid tie. This was a while back so i am sure the rules have changed.
Bottom line is to check with the local planning and permit department. From e-mail exchanges I have had they are very helpful in guiding you before you start plunking down $$$$
