Properly wiring AC disconnect help needed..
Inspectors have to find problems or it doesn't appear they are doing their job. On a recent final inspection of some carports we installed at work, the city inspector noticed a tree on the original landscaping plans from 1982 that was missing at the main entrance. The building owner and aerial photo records confirm a tree has not been there for 38 years but they said we either plant a tree or fight to get a variance. We're going to drop a 15-gallon mesquite in there in order to pass inspection and then in about 30-days it will probably get tossed in the dumpster after a truck driver flattens it because of the corner location.
Dave W. Gilbert AZ
6.63kW grid-tie ownerComment
Salts, bcroe, PVAndy, and Mike90250,
Thanks for all the input. Seems like I should call the local Inspector and see what he wants and post the results,Comment
I am glad I live in the Wild West. Never had an issue with an inspector, but these are not soSome areas, drilling a box is "modifying" and then the box looses it's rating. And you have to use approved hardware, stainless starwasher. I had to use the prefab greenwire crimped into a ring terminal, at $3 each before my inspector was happy. All depends on who you get.
fussy. Half the conduit holes I need are not provided with the right size knock out at the
right location, esp the larger ones, so I just punch the needed hole. I tend to run ground
wires even when they are not required, think the ground bar was at a big box electrical dept,
but they get mounted where I need them. Bruce RoeComment
bcroe, I live an hour west of Vegas in a small town. Just got off the phone with the local Inspector and he said it was ok to drill a hole in the AC disconnect and use a ground screw and run the green wire into the Service Panel.
Thanks for everyones input.Comment
Needs to be a threaded screw, star lock washer adn nut. remember to sand off paint/ Every now and then one of our electricians uses a self tapping or sheet metal screw and we fail an inspection.
AndyComment
Ok. Not to sound stupid but do you use 2 star washers, one under the head of the screw to grab the bare copper wire and another one under the nut.Comment
A double washer should get you a better connection. I would then use an ohm meter to check to see if the metal case is actually grounded. If you get 0 ohms then you know you have a good connection.Comment
