There's a recent flood of these on ebay for around $300, has anyone had any experience with the CP model? I currently have a BATRIUM BMS so I don't think I will need the WIZBANG Jr or other stuff. I will have 4k watt of solar panels(39.82 VOC, 9.78 ISC panel), and 10kwh of battery storage. Can anyone shed some light on this model? thanks
Midnite Solar Classic 250 CP model question?
This is the true info from the Mfg. All the fleabay sites do is add some cost for their trouble.
begin fwd message:
The Classic 250-CP is a Standard Classic that was a custom order.
They DO NOT have multiple MNGP slots so they can not be used in Follow me.
They DO NOT have AUX 1 or 2 terminals so they can't be used with a WBJR or any AUX functions.
THey do not have ARC Fault protection.
MNGP can not be programed for Voice. (there is no speaker installed in these MNGP)
None of these features can be added back to this board.
They DO HAVE an Ethernet Port so they can be used with MM2 and the Local App.
They can be updated normally using our normal Firmware via USB
They have Ground Fault Protection
BTS input jack is functioning
Most of them still are under warranty and will carry that warranty until they reach the 5 year mark.
Price on this item is $250.00 each. First come first served.
Please email sales@midnitesolar.com to order.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks @Mike90250 for the info. Do you recommend the CP model? Any other MPPT charger you would recommend within the $200-$400 range for a 48v system?Comment
I bought one of the -CP to use as a spare. I trust them that much, and it's such a deal. it still has the ethernet, so programming changes via their Local App would still work.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
