Years ago in college we did experiments using optical stress analysis. A brittle lacquer spray would be applied to a test object and they we would stress it. The cracks in the lacquer would line up with the calculated peak stress lines and if I remember correctly the spacing between the cracks were proportional to the stress.I also think it lined up with the dreaded Mohrs circle which was graphical way of avoiding vector analysis of stress when slide rules ruled the world. Luckily my freshmen engineering class was the first one where everyone was required to have calculator and slide rules were banned from use in classes.
Newbie question - cracks in solar panel glass
Interferometry and is a great analysis tool, but I'm still a fan of understanding Mohr's circle as a way to get the most out of such newer methods.
FWIW, we could use calculators unless the lesson being taught involved how to analyze a situation, or the Prof. was real old school. Generally calculators were allowed for exams, but usually all homework required showing calcs. until grad school. Toughest undergrad exams I had were from a prof who taught a course in in engineering mathematics. His exams were always open book and the answers would be given and be deceptively simple like "pi", "e", 0,1,-1, etc. The student would then need to explain and show w/calcs with why the answer was what it was. Worst answer I recall - because everyone bitched loudly about it - was (e^pi)/10 involving the probability dist. of failures in a production process. Nobody got that one. Big PITA.
Back on topic.Comment
I agree 100%, that's why I was asking the OP if he did. While it may no appear to do damage, it does in the long run.Comment
Hi All
I have 2 Jaycar ZM9059 150W 12V Panels, of which one of them has the snail trail cracks, I have asked Jaycar for comment. The one beside it is fine. Has anybody else had this problem. It appears at this stage not to be effecting the performance.
Image2-Panel.jpgAttached FilesComment
Those look like scratches. Snail trails are fatter and not usually as straight. But it's not right for sure.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hi All
I note that a lot/most of the cracks are at 45 deg. to the major axes. If there are more localized cracks, that may indicate induced stresses, perhaps from differential thermal expansion, wind loading or combinations of other external loading(s).Comment
Impossible to walk on and even if you could I'd expect the cracks to be on the outside. It's too spread across the panel for it to be a kids ball etc and again the cracks are internal. Hoping someone has also come across this problem.Comment
Sorry, I'm not highly educated on solar panels but looking at Youtube the other day I stumbled upon this one where a guy goes over several different problems that can befall PV panels. I thought the guy did a good job of explaining several things. It might help. https://www.youtube.com/watch?v=Rw8XuB0BSVIComment
