It is common for the PoCo meter to make no connection to the neutral. It just assumes that
the load is balanced, including power factor. Bruce Roe
trying to monitor my Enphase iq7+ using a smart meter
Even though the diagram shows the neutral passing through, I suspect it is being used by the meter for power or reference.Leave a comment:
I looked hard at the Sense device. I just think that it really sucks that you cannot "teach" it devices, by having it "learn" by starting that device and having it observe. I know that it learns over time, but that seems real cumbersome.
I'll probably buy the Enphase Envoy, but I'll wait until the IQ8 comes out, since those look to be pretty game changing and, I am sure, will require a new Envoy then too.
My feed is into a sub panel that I can safely isolate and dig around in. I just added a 20 amp 1-pole breaker last night, for an instant water heater under my kitchen sink, in fact. So, wiring up a CT would be not too big a deal. I just went the smart power meter and socket route since it seems much more robust than the chinese junk I'd end up with from eBay or Amazon.
In the meantime there is a Neurio on Ebay currently for $100.Neurio has a good phone app and an interface with IFTTT so you can program it to send you a text or email when your solar production hits a predetermined set point. For what it is worth the Neurio is what the Tesla Powerwall uses for its current sensing to inform the various charging and discharging modes of the Powerwall. That being said, the product has not evolved much in the year I have owned it but it serves its limited purpose. This is a hobby for me so I don't measure ROI on information technology. LOL
Mine is obviously a second meter that measures only the output of my system. My regular power meter is a smart meter that the utility enabled once I got my distributed generator permission to operate. It displays the net power that is exported (no payment back) to the grid. I have my total kWHr to date, just fine. But, what I would really like is to be able to stand there and see exactly how much power my system is producing AT THAT INSTANT. For some reason, that part is not working.
My feed is into a sub panel that I can safely isolate and dig around in. I just added a 20 amp 1-pole breaker last night, for an instant water heater under my kitchen sink, in fact. So, wiring up a CT would be not too big a deal. I just went the smart power meter and socket route since it seems much more robust than the chinese junk I'd end up with from eBay or Amazon.Leave a comment:
Sorry, sounds like you got it right. I monitor my total house consumption through our house smart meter from our power company. They provide an app with real time readings for like $3 per month. Doesn't tell array total production but our house usage is pretty constant so we can get close figuring it out.Leave a comment:
Do those devices use current clamps.? I have used the Sense and the Neurio which both have good phone apps and give you peaks instantaneously. They are several hundred dollars new but I found the Neurio used on EBay. They use clamps around your main sevice panel cable and around your solar wires in the breaker box. You have to be comfortable around electricity to attach the clamps and provide power to the devices with a separate breaker.
For less money you can try an interface with a Zigbee smart meter of you have a smart meter. These are called HAN devices and you have to go through a cumbersome registration process with your power company if they offer that service. They only show net power and you dont get a separate measure of solar output. The one I use is called Rainforest.Last edited by Ampster; 03-18-2019, 09:02 AM.Leave a comment:
We have a 7k system with 24 IQ7+'s. The cost for the enphase monitor is too much $.Leave a comment:
So, I have a small Enphase system. 8 panels and 8 microinverters. It doesn't make sense to add the envoy-S-IQ for another $450 to monitor my system, as that would be a years production down the drain. So, I bought an Itron smart power meter on eBay. It was advertised as having a simple program that would tell cumulative kWhr, Instantaneous kW, and peak kW. I installed it between the array and my subpanel that I feed into. The cumulative reading works fine. But, I get two peak readings. No instantaneous reading at all. I wrote the seller and he was no help.
So, I bought a GE-i210+CE smart meter on eBay for $20. Supposed to be new. I plugged it into the socket and it gave me a "2 kWHr" and an "err" where the instantaneous current should be. I figured it was defective and asked to return it. He told me to just toss it. The manual describes an ERROR reading as an irreparable internal fault. I bought a third meter, brand new. It was the same GE model, and did exactly the same thing with the internal fault business. No way they are both bad, combined with the odd behavior on the first meter..... Urrrghhhh.
I am thinking that I have made an error, wiring wise, or that these meters cannot handle the eNphase stuff ??? The wiring looks really simple. I have the two a/c feeds coming in, and the same two leaving the other side of the meter. The smart power meters say "3-wire" but they just show the neutral going past the meter and have no connection for it.
Anyone have an idea of what gives ??
