String Inverter For 3 Wire 3 Phase 240 Delta
  • wardneal
    • Feb 2018
    • 20
    Hi Everyone
    Looking to start my long awaited project in the next few weeks.
    I have a contract for 50 panels 350w or 17.75kw system.
    Here is the problem. I have a two transformer on the power company pole that provides me with 1 200amp 3 wire 240 delta.
    Then I have 2 200amp services that are pulled from the low legs of the delta with a third wire ground. All of these go to separate breaker panels.
    I was going to use a 15kw 3 phase inverter but with 240 three wire no neutral I have not found one that will work.
    So is my best option to use 3 5kw single 240 inverters?
    I would have to have a strange animal for my project.
    Thanks Neal
    • 15184
    I believe there are a number of companies that make a 3 phase inverter but they may not be exactly what you need since you are on what I think is a 240V open Delta line.
    To make sure you get the correct one I would contact your POCO to find out what they feel will work on the power distribution line you are connected to.
