Im not a pro, but like owning good tools. It seems like the swing is crazy cheap to the high end one. Is there a crimper out there you would recommend?
Any crimper under $100 worth buying?
As long as you understand their limits, some won't have a full set of dies, most are not certifiable, and even the 20 ton hydraulic have their limitsPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
For what gauge? If you are planning correctly, you should never need anything larger than 4 AWG. Best bet is just buying terminated cables. Lots of places wil make them to any size or length. In addition many electrical supply rent them out, or find an Electrical Contractor and have him terminate the cables.
You can find some used T&B TBM21E or TBM25 on Flea Bay should be more than what you need for $100 or less.
Guess it might help if I post the gauge.
Both my systems use 10awg, I have a friend who is an installer with a set I can use but would rather have one in the tool box Incase I need some in the future.
The pre terminated ones scare me since I donLast edited by Dsspro; 03-15-2018, 06:30 PM.Comment
If 10 AWG is the largest, that is easy peazy my friend. For A. B, C non-insulated, and RA, RC, RC insulated nylon and vinyl terminals and splices nothing better than a T&B WT112M for less than $40 new. Most electrical supply stores sell them. 26 to 8 AWG
Nice and heavy, make excellent Rat/Cat/Squirrel killers, and an attitude adjustment tool to keep wife, kids, and electricians in line.
Thanks SunKing. I guess I should have been more specific unless the answer doesnComment
Yes you should and you need to learn how to use GOOGLE to search. There are dozens of MC4 Crimp tools available for $50 or less.
Look for: A-2546B MC4 Solar Connector Crimping Tools on 2.5-6.0mm2
MSEE, PEComment
I have a cheap MC-3/4 crimper I bought on ebay and it works perfectly. I have crimped hundreds MC-4 crimping tool.jpg connectors and cant find any fault with it. I have the type shown in the picture. I also have the type that opens more like scissors or pliers. Don't care for it anywhere near as much as this type shown here.Last edited by littleharbor; 03-21-2018, 04:37 PM.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
The type shown is what I have been using with good results, ignoring that little hinge thing
on the side. The latest experiment of 24 landscape mounted panels, with an open gap
between the upper and lower rows, meant I had to make 10 MC4 extension cords to tie
together 2 strings.
Has anyone seen a proper way to splice together lengths of 10 gauge PV wire for outdoor
use, other than crimping on an MC4 pair? Bruce RoeComment
Or Underground splices. Or real easy and practical Twist Lock splices rated for underground by Ideal Industries.
I've seen wire nuts (twist locks) for 24V sprinkler systems with dielectric goop in them, but not for 240VAC. Guess I never needed them.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
