No unfortunately the MS Classic 150 cannot communicate with the SW thru the Xanbus, Only Schneider / Conext Products can "talk" to each other. But the reason I went with MS C150 is due to...
1. MidNite's stellar products. I really like the combo of the 150 and the Whiz Bang JR. Using the NOT MS local app called "Classic" in the Google Play store, it will let you see just about everything going on in the system, including the watts and amps being used at that moment. And the MS local app lets you change settings on the 150 (but note: the 2 apps cannot be used together, you MUST close one to use the other or they will not work on your LAN)
2. the Classic 150's ability to be connected and controlled via the Local MS App ...WITHOUT the need for a ComBox like extra that the SW requires. The Combox is very costly, but if you are already getting a combox, I guess the Conext would be OK.
3. MidNite has the sizing tool calc that allowed me to plan the largest array possible and size it to the right size CC for the money. (Web search "MidNite Solar sizing tool" and you will find it. Very helpful)
All that said ... I probably will get a a Combox tomorrow if I can find a Cyber Monday deal
I currently have the SW 4024, a BTS for the SW, the SCP and the Battery Monitor with another Temp Sensor. The combox will allows me control of the SW from inside the house or the web. Also ... you need the Combox for doing any Firmware updates to the SW, Which kinda bends me out of shape about Conext products. Kinda hard to believe after you've spent about 1500 for the SW you cannot do updates unless you spend another 450 for the combox. Robbery. So not really impressed with Conext.
If you try to PM me I will answer, but as of yet I have not found where this forum allows for PMs.
