The link pics aren't coming through on my Apple. But if the modulation is on the order of the line
frequency, you can forget about beads helping. Apparently the distortion on the basic 60HZ is
being seen as a fault. Equipment exists to help, but at the operating power level could be quite
costly. Maybe removing the generator is the best solution, if you can't turn off the detector in
the inverter. Bruce Roe
