Oh I know all about entropy, how when energy is converted from one form to another, the new form has less energy than its original (and is why every perpetual motion machine on YouTube is put forth by someone who's trying to trick you, is delusional, or both, but I digress).
I agree with you in principle, but it's not that simple for end-users to know which is actually "better." For your example above, say the person across the street from the power plant needs to buy a new hot water heater. He sees two in the store, both the same size and same price, one gas, one electric. One says it uses $250 a year to run while the other says it takes $200. Which should the buyer purchase? I didn't say which was which, and that's the point. One may have a more efficient design, or may have better (or worse) insulation. Then there's the case of extenuating circumstances. Buying a heat-pump style electric hot water heater makes since if it sits in a hot garage which you wish was cooler.
I get what you're saying, but how a piece of equipment is designed can undo much - or all - of that energy's natural advantages.
