Or what passes for one.
I already have an intro thread but not a walk-through of my planned build, so here goes.
Currently I'm finding it surprisingly involved to determine what size system is needed, so while I flounder around with that, I at least did a site survey. Our house is really small and not oriented well for panels, and due the topology of the yard, a ground mount works out better. We have a terraced rear bank that runs NE-to-SW at 220 degrees, with significant shading toward the east which I can't do anything about - see the attached "Solar Shades" scan of the site. The terraced rear bank has a ~10-ft wide flat "step" which contain a concrete drain swale with the likely PV area being approximately 11'-wide x 66'-long. I want the panels as low profile as possible because whatever's up on the bank is very visible not only from the house but the street as well. I'd like to orient them in landscape format, 1 tall x 2 wide, spaced in rows to avoid self-shading. The front edge would be just high enough to avoid small weeds, tipped at around 25 degrees and facing 220 degrees. You can see from the attached that coincidently, that's probably about perfect. The 10-11' long assemblies will straddle the concrete drains, which isn't a usable space anyway, so that works out well. The maximum height should be around 24" or so which minimizes the eyesore and the wrong kind of attention. (As an aside, pole mount setups are doubly bad, both in terms of visibility and because the terrible clay/sandstone soil making boring deep holes nearly impossible. The rear bank also has no access for heavy machinery.)
We've had one quote done ($18,000) which recommended a 5.6KW setup. The thing is, shortly before the quote was done we redid our koi pond, increasing power usage somewhat. As a result, the quote's based on just a few months of increased usage, and they estimated the yearly monthly average to be around 700KWh. I'm pretty sure that's going to prove a bit low but we'll see as the months progress. As I mentioned in the intro, me being an EE, I gradually decided to do the installation myself (one of my hobbies is building cars from scratch, the latest being a mid-engine two-seater resembling a Lotus Seven - Goggle "Midlana" to go there, but I digress. Other future additions to the electrical system may include a EV and/or a battery depending on incentives, but I'm getting ahead of myself.
Anyhow, due to the very helpful people I've already met here I know I have my work cut out for me just determining panel count. I guess the first thing is to get a better estimate on the average daily or monthly usage. I should be able to extrapolate the usage for the months we have to get something fairly accurate.
Other stuff... we use SDG&E, so TOU 2.0 is looming for next year and will be defined as 4-9pm. While this makes it more difficult to fill that time slot with power, as you can see from the site plot, it's pretty clear off toward the west. If I choose, the panels could be angled even straight west if that ends up being economically the best direction.
Enough typing for now, more later.
