dailo can you tell me how you reset your inverter ?
Solaredge inverter reliability
I just flipped the switch to turn it off. After it came down completely I flipped the breaker and waited a minute before turning everything back on.Comment
Unfortunately it did not work for me I even turned the breaker off for 10 minutes. I will see if this firmware update helps that they are talking aboutComment
The breaker you flipped was it the breaker to the solar inverter or the breaker for the entire house? I just tried the breaker outside connected to the inverter so farComment
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
I just got an error code on my Solaredge 7600HD inverter-says 18xB7 then it says HW error and the red fault light is on. I called Solaredge support and they said they are updating the firmware and said it will take all night and to check tomorrow if it fixes the issues
Keep an eye on it as i have been having issues wth my 7600 HD since install on January 2018. They keep updating the firmware and seems to resolve the issue temporarily. Now my temps are in the 180 range during mid day here in Florida. I looked at the inverter cabling and all looks well. This is causing my Inveter to derate the power it is making
Okay thanks I will. I attached the firmware version that shows up right now. Maybe it will be different in the morningAttached FilesLast edited by Afrmthabay; 04-05-2018, 01:50 AM.Comment
This is what my inverter shows. I did see the error on a day where it was pretty warm, so hoping I don't see this error more frequently as it gets warmer.
Screen Shot 2018-04-05 at 10.45.09 AM.pngComment
Well I spoke with Solaredge this morning and they confirmed a capacitor failure on my inverter and my installer called Solaredge and they are shipping a new inverter - should get here within 7-10 business daysComment
Anyone more knowledgeable, know why charging a car could potentially cause this? When I was hitting this issue as soon as my charger started the error would pop up. Only after resetting the inverter was I able to charge my car and have the inverter running at the same time. Trying to understand how the inverter would act any differently if power was going to the grid vs being consumed.Comment
I have a new one in route as well. Should be here by tomorrow. This one was brand new installed in December 2017 and commisioned in Jan 2018. Here is my firmware version. Mine was updated 4 times since Jan 2018.Attached FilesLast edited by TundraLu; 04-05-2018, 03:40 PM.Comment
do you have a solaredge integrated car charger? if not then what kind of car charger do you have?Anyone more knowledgeable, know why charging a car could potentially cause this? When I was hitting this issue as soon as my charger started the error would pop up. Only after resetting the inverter was I able to charge my car and have the inverter running at the same time. Trying to understand how the inverter would act any differently if power was going to the grid vs being consumed.
I could see it lowering voltage if the voltage was already borderline, could be some odd harmonic issues if the charger is poor quality.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
My car charger is simply grounded to my inverter - Solaredge mentioned something about changes in the electricity or the harmonics in the electricity changes which can trigger the fault and they have better firmware to combat that. Electrical is not my background but it does appear there is some relation. Hopefully they have a way to make it work with new firmware or anything to alleviate that. But simply grounding my car charger to inverter would not cause the fault they said but the harmonics in general could is what they told meLast edited by Afrmthabay; 04-05-2018, 04:25 PM.Comment
