Enphase Envoy-S metered - waterproof CT's for outdoor install
I hope you just read the rating on the side of the CT to know what their ratio.
It is the secondary value that determines if they are compatible with the metering device. Common inputs to meter are 1 amp, 5 amp or 333mv.
The primary value will just determine if you are in the bottom, middle or upper part of the measuring scale.Comment
Unfortunatelly, that's not even close and the actual value does not fall anywhere near the typical bracketsComment
So what type of input value (amps or mv) does your meter require?
I have been purchasing and use CT's for a long time and unless the requirement is very unique most meters accept the 3 standard input values I mentioned.Comment
Butch
Are you familiar with the CT-200 that Enphase used for there metering. The only information I can find shows what I think is a 200A to 500mv ratio but I am not sure if that 0.5V is a maximum rating or the actual input requirement to the Enphase meter.Comment
I saw the same thing. We do very few enphase installs (only small ones) and have done none with the consumption meter.
We do a lot of solaredge installs and many with consumption meter. We have often had to use Rogowski coils for these installs as well as with FLEX energy hubs.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Enphase engineered an odd ball. Not sure if that is to insure people are buying their CT equipment?
200A@0.4VComment
You might be right on them wanting you to only use their equipment. Although Flex Core does make some nice and affordable CT's with many different ratios.
The Enphase meter may work using a 333mv or .333v input. Sometimes a meter manufacturer provides the max input values but allows you to go a little lower. The problem would be the accuracy could suffer.Comment
there are a few listed on hqmeter with 0.4V output. like the JC16F, JC24F, etc.
yup, looked at them early on. unfortunately neither one had the right turn ratio or was weatherproof,
http://www.hqmeter.com/split-core-ct.html
which is why I ended up with the custom unit build to my specs
