A BIG thanks to sensij & JSchnee21 for your help. You guys gave me confidence to open up that shiny new inverter and make the change from cellular to LAN. Very easy. I had to cut off and crimp a new RJ45 plug onto the network cable because the plug wouldn't fit through the (stucco) wall grommet nor the cable "gland" (why do they call it that?) on the bottom of the inverter. I did leave the cellular modem connected though. Changed the server settings to LAN/port 502 (DHCP), Got the "11111111" and it seems to be working well. I'm now getting immediate updates every 15-minutes. Much better than those data batches every 4-hours. As for granularity, how do I enable 5-minute reports?
SolarEdge Cellular Monitoring Kit
gland2A BIG thanks to sensij & JSchnee21 for your help. You guys gave me confidence to open up that shiny new inverter and make the change from cellular to LAN. Very easy. I had to cut off and crimp a new RJ45 plug onto the network cable because the plug wouldn't fit through the (stucco) wall grommet nor the cable "gland" (why do they call it that?) on the bottom of the inverter. I did leave the cellular modem connected though. Changed the server settings to LAN/port 502 (DHCP), Got the "11111111" and it seems to be working well. I'm now getting immediate updates every 15-minutes. Much better than those data batches every 4-hours. As for granularity, how do I enable 5-minute reports?
ɡland/
noun
noun: gland; plural noun: glands- a sleeve used to produce a seal around a piston rod or other shaft.
