I've been hearing that for some time now, and unless some unusual circumstances intervene, I continue to question the validity of that statement for most locations.
Assuming ground mounted arrays where you get to pick orientations, haul up PVWatts and try this: Using 1 kW array size, run 3 orientations, 135 deg., 180 deg. and 225 deg. , all tilted at latitude.
Compare the outputs.
Compare: Which array of the three has the most output ?
Compare: How does the total of two, 500 Watt arrays, one facing 135 deg., the other one facing 225 deg. compare to the output of one, 1,000 Watt array ?
Any comparison I've made has the single, south facing array producing slightly more than sum of the two, 500 Watt arrays at 135 and 225 deg. orientations. There may be some locations where that may not hold, but I've yet to find one, or even conjure one up, except such as, for example, where a south facing mountain/building/obstruction shades an array between 1100- 1300 hrs. solar time.
Particulars of each application like shading, available space, etc., or, in the case of a roof location, may make one orientation better than the others, and that's usually the case, but, speaking in general terms and of production only, not revenue considerations for tariffs such as T.O.U., for most locations that have a viable solar climate, one orientation is almost always more productive than two in terms of annual output per installed kW, and that orientation is usually and mostly south facing.
For off grid applications, because of battery charging requirements and/or use patterns etc., there may be some value to split/several orientations to level out hourly production a bit or produce more output at off solar noon time(s), but that's particular to each application, rather than a general precept, and if grid tied, mostly a moot point as far as production times are concerned.
Even with most T.O.U. tariffs, one orientation is usually more profitable in terms of revenue, at least as most currently constructed T.O.U. tariffs seem to be working.
Bottom line: For most grid tie applications and locations, given the options of single or multiple orientations, choosing multiple orientations on the premise that such an arrangement will produce the same or greater output per installed kW on an annual basis than a single orientation is probably not a good assumption, is probably not correct or at least questionable for most applications and locations, and therefore perhaps not the best place to begin a design.
I also question the wisdom of assuming the cost of a split array in terms of $$'s and complexity/reliability will come in the same or less than for a single array. I'm sure the footprints will also be different.
