Originally posted by thundercowpoke
View Post
To do that you need a Hybrid Inverter or as Butch calls then Bimodal and that requires batteries. The generator, wind, and solar have to be converted to DC power than converted to AC power to sync up. That would be very foolish.
Your two options are:
1. No Solar, just commercial power and a Generator with ATS switch to give you power during outages. Gives you exactly what you want and the most bang for your buck.
2. You got money to throw away and want solar in OK. No problem use a conventional Grid Tied System and the exact same generator and ATS switch for when power is out.
Forget the Wind Turd as they are not worth their time or money. In a year or two will be worthless junk that needs replaced. For a Wind Turd to work requires them to be on a Tower well abovetree and all obstructions.. In a year or two you will have to figure out how to get it down to replace it when it quits working. Either the bearing will wear out, strong wind burns the brake up, or lightning hits and burns up your electrical system. You do not want anything to do with a Wind Turd.
