Ya I'm doing 2 rows of 6 panels and 1 row of 3 panels. I imagine there's someone on this forum that used Unirac......
diy solar grid tie
it's going to be the Unirac light rain 20 ft. Basically if it's 1 inch extra then I'll be good. I'm definitely going to call unirac on Monday.Comment
Just my luck the Unirac are exact measurements.
So my SolarWorld panels are 39.41" wide portrait, should I put the first Enphase M250 micro inverter at 25" and then 50" thereafter?
How wide is the space between modules for the midclamps?
How much space is needed for the end clamps?
Probably is enough to make it so won't fit in 240 inches, but I haven't looked up the numbers.
Have you already ordered the racking?
IIRC I used 11' ironridge rails for my 6-module/row array. (with splice near the middle and trimmed to be a little shorter than 22'.)
Maybe you can change from 20' to shorter ones and splice.
If it were me, I'd want the splice to have two feet on each side of the splice.
I definitely wouldn't want to try to splice on just 1 foot of rail - I would be worried about it - especially since the end modules of an array are more likely to have more wind force on them.Comment
For the 240" rail it just fits. But for my last row of 3 panels I need to be creative, Renvu gave me wrong measurements for the end clamp. My delivery is scheduled for today......talk about a learning experience.Comment
Make sure you tell Enphase that you are the installer in the account setup, so that you don't have to pay extra for the Enlighten Manager.
Oh, and make sure to keep track of which inverter goes under which panel, maybe take a picture of each label. You'll need that info to "build" the array on the website. I don't remember if there is anything you can do before turning on the inverters, but I had my system up and running (without the Envoy) before I even took the envoy out of the box. Setting up the Envoy and monitoring was the last thing I did.
Another tip: If the panels come in a box on a pallet, with the panels resting on their sides, be careful how you remove them. After I'd removed about 2/3 of them, I realized that the panels I had removed were the only things keeping the box and the remaining panels from tipping over. That was embarrassing. I had to get my wife to keep the box from tipping as I removed the remaining panels.
Ok thanks. The panels have a little bit of adhesive from the scotch tape over some of the PV cell on the side, how do I clan the panel?Comment
A little water and an old credit card should be sufficient to scrape scotch tape residue off I think. (credit card plastic should be soft enough not to scratch the glass)Comment
The problem with cleaning the front side glass, is the Anti-Reflection coating can easily be damaged. Tape residue can be removed from plain glass using lighter fluid for wick lighters (I think it's naphtha). I'm not sure if it's safe for the panel edge seals or the AR coating, but apparently it's safe to use on expensive guitars:
http://theunofficialmartinguitarforu...m/topic/136591Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
My array was approved with pge the 19th the same day I submitted the interconnect form. my 285 watt panels with m250 microinverters are producing 220 watts at peak, is that sound normal? The panels are 14 degree tilt and facing 200 degrees.
IMG_20161019_083700.jpg IMG_20161017_190857.jpg IMG_20161016_155650.jpg IMG_20161016_120842.jpg IMG_20161016_115752.jpg IMG_20161013_183301.jpg IMG_20161013_100452.jpg IMG_20161012_190226.jpg IMG_20141024_122414254.jpg IMG_20161020_130203.jpgComment
If you're PGE you're probably not too far from me - I'm in the south bay.
I have 285W panels with solaredge system.
I am getting a peak of about 195-205W for my panels at ~165 degrees and ~18 degree tilt.
