The problem with grid voltage is that the POCO can adjust it by changing out transformer "taps". Unfortunately while this may help someone that had very high voltage near the transformer, someone at the far end now has very low voltage which can cause their appliances to run less efficient or actually burn out. It can happen the other way as well by raising up the voltage at the far end a little, now makes it too high for the customers closer to the transformer.
It becomes a balancing act to keep the voltage up and down a "feeder" between a "High and Low" specification allowed so that the customers do not have problems on their loads. Otherwise you end up having to install equipment at a customers distribution panel which can get expensive.
