Does anyone know what I would search for to find something that will safe guard solar panels from squirrels, critters, pigeons, and other things of a similar nature? Is there a product out there designed for this? Any and all thoughts on the matter are greatly welcomed / i cant figure out what to search for in order to find the right product i am looking for
How to Safeguard Solar panels from critters like squirrels, pigeons, etc.
are you having a problem with critters? and if you do have some nesting under panels, is there any evidence of damage?Comment
found any pest that will chew through steel. Bruce RoeComment
Beware when adding critter guards around the backside of panels, the upper end will collect debris and will need periodic cleaning.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
That I suppose, is if the guard is close to a roof? I'm adding that as #25 to my list of advantages of a ground mount where practical. Bruce RoeComment
